Date: 12-05-26  Time: 02:33 am
Author Topic: starting problem  (Read 4942 times)
jimbojim
starting problem
« on: 28 April 2015, 08:28:16 pm »
Hi all ive got a slight problem, whilst coming home from work today I stopped at a shop when I came back to the bike it wouldn't start just buzzing noise under the fuse box I managed to bump it off and it started off the start button after that, it done it once before a couple of months ago but has been fine until today, any ideas please
noggythenog
Re: starting problem
« Reply #1 on: 28 April 2015, 08:32:49 pm »
Sounds like your battery is goosed Jimbo
jimbojim
« Reply #2 on: 28 April 2015, 08:54:30 pm »
I was thinking that mate but it starts on the button every time apart from today and a couple of months ago even if I haven't used it for a couple of weeks it starts first time. I thought iffy starter/selanoid  maybe
« Reply #3 on: 28 April 2015, 09:34:55 pm »
 A multimeter is a useful bit of kit to help pinpoint these sorts of problems.
Clean and tighten all the electrical connections and squirt a bit of contact cleaner at all the switches before assuming the battery is knackered.
bandit
« Reply #4 on: 28 April 2015, 09:35:17 pm »
Hi, you are right the buzzing noise is the solenoid but before you change check battery connections & all others leading to the solenoid & starter motor are all clean/tight. If it fails to start on the button again put bike in first gear ignition off & move bike forward & back put back into neutral switch ignition on, if it starts on button suspect faulty starter motor.
jimbojim
« Reply #5 on: 29 April 2015, 03:15:59 pm »
thanks for all the tips thats my job for the weekend then, again thanks for the help
jimbojim
« Reply #6 on: 01 May 2015, 09:31:49 pm »
Hi all, changed the solenoid and made no difference, got the battery checked and found it is dead so new battery required
sinto
« Reply #7 on: 01 May 2015, 09:46:00 pm »
Are you sure it's dead?
I remember an old bike I had, the battery showed dead but I stuck it on an optimizer for a few days and lo and behold, brought it back to life and continued to use it, all I done afterwards was kept it on a trickle charge and never had to buy a battery so maybe worth a try?
« Reply #8 on: 02 May 2015, 09:16:36 am »
Batteries only realistically have a few years of optimum performance, if that.
Remember they are charged EVERY time the bike is used, that's a lot of charging and discharging.
A phone's battery has a fair life expectancy of TWO years so once you consider the shite a bikes battery gets put through, especially with hot/cold temperatures, then it only makes sense to change it when you get a hint of problems.
And for the amount of years you'll get out of a decent brand, it makes no sense to cut corners and save £10 or £20 on an inferior battery.
The chances are you'll only ever buy one (perhaps two at a stretch) battery for the whole time you own the bike.
jimbojim
« Reply #9 on: 02 May 2015, 07:11:03 pm »
changed the battery it fired up first push of the starter button :), no point fookin about at least I don't have to worry about the battery for a long while
sinto
« Reply #10 on: 02 May 2015, 07:36:33 pm »
Glad you got it sorted now :-)
