Date: 22-03-26  Time: 14:01 pm
Author Topic: slight oil leak  (Read 10936 times)
Paulfzs
slight oil leak
« on: 12 April 2015, 04:05:31 pm »
was under my fazer today having a lube up of the chain and centre stand when i felt burning oil drip onto my hand, its only a small drip every minute or so and appears to be coming from the sprocket cover.
so clutch rod or gear selector shaft...
whats it more likely to be?
i was thinking maybe clutch shaft has dirt in it or something?
rhinoeli
Re: slight oil leak
« Reply #1 on: 12 April 2015, 04:13:17 pm »
Chain lube maybe?  :b
Paulfzs
Re: slight oil leak
« Reply #2 on: 12 April 2015, 04:14:25 pm »
was black and dripping from the engine and very hot!
Re: slight oil leak
« Reply #3 on: 12 April 2015, 04:20:44 pm »
I would of thought that it does get hot in there and mixed with all that crap inthere it is black, mine was when I took the cover off to clean, if you give it a good clean out in there it may go away, mine have a gunk tunnel of solid grease that the chain went through.
Have a look here http://foc-u.co.uk/index.php/topic,10769.0.html this chap had a chain snap and it snapped his push rod and gouged out the seal and yet no drips
anutz
Re: slight oil leak
« Reply #4 on: 12 April 2015, 04:30:11 pm »
look at my pics here - my sprocket cover was a mess, so it may well be from there as fazersharp commented....
http://foc-u.co.uk/index.php/topic,16313.0.html
cannot think where else it would be from but i am no expert ( yet...)
i however had  not seen any drips on my floor or noticed any dripping after riding and parking in the garage
Paulfzs
Re: slight oil leak
« Reply #5 on: 12 April 2015, 04:32:10 pm »
suppose i should go take my cover off and see whats going on.
mention of a ball bearing behind the push rod, can i pull the push rod out and leave the ball bearing in there?
will pull my shaft and have a look.
anutz
Re: slight oil leak
« Reply #6 on: 12 April 2015, 04:45:20 pm »
never pulled the shaft out much but someone on here recently was talking about pulling the push rod out and if it could cause any issues.....i will try find it - i don't think it did as they had pictures of it once they cleaned it up....and it was fully removed....
Re: slight oil leak
« Reply #7 on: 12 April 2015, 04:51:11 pm »
Twas me and its all in that link with pictures push rod out no probs ball baring stays inside
Here
anutz
Re: slight oil leak
« Reply #8 on: 12 April 2015, 04:53:22 pm »
i didn't click the link fazer#  :b , apologies! :)
anutz
Re: slight oil leak
« Reply #9 on: 12 April 2015, 04:53:56 pm »
Did you put a new Sprocket Cover Gasket on....i did not.....and its been fine....
Re: slight oil leak
« Reply #10 on: 12 April 2015, 05:12:15 pm »
Yes I did as I got it cheep from ebay --- well if you can call £5 for a piece of paper or whatever cheep,as you can see from the black remnants in the pic they tend to weld themselves on, so I lightly greased both sides of the gasket to stop it sticking for the next time i took the cover off
But the general consensus is that you do not need the gasket but you may have to alter the clutch slightly to compensate for it no longer being there
Edit ---------- maybe Paulfzs has found a reason why you do need the gasket - maybe he has not got one
anutz
Re: slight oil leak
« Reply #11 on: 12 April 2015, 05:18:22 pm »
i don't have one..... :eek
mine was toast - i just re-assembled and thought i will watch it.....
seems to have been fine and clutch behavior is OK for now..well the engines in bits as we know so it was ok
Paulfzs
Re: slight oil leak
« Reply #12 on: 12 April 2015, 05:45:09 pm »
took cover off, slight oil in/around one of the metal things (forgot name) that make the cover line up with the rest of the engine...
no gasket but its never had a gasket since the engine change over 1300 miles ago and never leaked.
cleaned it all up gave it a blast off with a hose so now ill wait and see, i might have to jetwash the crud out so i can get a better view though.
gear lever shaft and clutch shaft aren't leaking oil, cant see it leaking from the final drive.
i had a few drips the other day after id been riding at high rpm so could be a mixture of thin oil that needs changing and a lot of pressure
i did however find 1 downpipe is a little lose so needs tightening and 1 of my rubbers is split through.. joy!
anutz
Re: slight oil leak
« Reply #13 on: 12 April 2015, 05:52:18 pm »
dowel pin?
Paulfzs
Re: slight oil leak
« Reply #14 on: 12 April 2015, 05:56:07 pm »
Re: slight oil leak
« Reply #15 on: 12 April 2015, 06:06:30 pm »
Clean it out with parafin
Re: slight oil leak
« Reply #16 on: 12 April 2015, 06:53:45 pm »
Here
Crikey, i've seen dirtier gloves on a snooker ref.  :lol
Re: slight oil leak
« Reply #17 on: 12 April 2015, 11:11:51 pm »
I dont want to get my bike dirty with dirty gloves now do i
Re: slight oil leak
« Reply #18 on: 12 April 2015, 11:23:12 pm »
Baby on the way :rollin :rollin :rollin
Re: slight oil leak
« Reply #19 on: 13 April 2015, 09:09:56 am »
Here
Looks like gloves in the picture but he's actually got a full body suit on
Re: slight oil leak
« Reply #20 on: 13 April 2015, 10:11:28 am »
Like the white room in Charlie & The Chocolate Factory.  :lol
I had to work on a film camera in that room in the last version of the film 11 years ago, but I only had to wear shoe covers to stop the floor getting dirty.  :D
Re: slight oil leak
« Reply #21 on: 13 April 2015, 12:30:09 pm »
Just going out to do a bit of maintenance on the bike :lol
Deefer666
Re: slight oil leak
« Reply #22 on: 14 April 2015, 11:25:26 pm »
The FZS does not need the sprocket cover gasket the only reason it was ever fitted was to stop the corrosion issue between two mating ali surfaces.
The oil leak will either be from the o ring that seals the push rod ...easy fix or the main output shaft seal behind the front sprocket... Not such an easy or cheap fix.
Paulfzs
Re: slight oil leak
« Reply #23 on: 30 April 2015, 02:33:35 pm »
So oil change done, correct amount of oil put in, other than a bit of clutch slip the oil leak is still there...
its still not dripping badly but it is leaving oil on the floor..
It appears to be coming from one of the bolt holes for the sprocket cover or one of the dowel pins.
there is a noticeable coating of oil on the sump where its dripped down...
Why would it be leaking from the down pin or bolt hole?
Punkstig
Re: slight oil leak
« Reply #24 on: 01 May 2015, 01:31:53 pm »
Only because the fluid has found that to be the easiest route using gravity!
