Date: 10-03-26  Time: 01:51 am
Author Topic: sidestand cut out switch not working  (Read 1638 times)
samsung
« on: 07 April 2015, 05:13:38 pm »
Before i remove the the said item,any advice would be much appreciated.The small piston is operating ok on the switch so i'm guessing it is the contacts inside it.Can i take it out of the loop easily?I have never had a bike that had one fitted.Any advice please will be welcome.
Re: sidestand cut out switch not working
« Reply #1 on: 07 April 2015, 06:33:54 pm »
Easy enough to bypass, but I would certainly would not recommend it for the same safety reasons it exists.
Take it off and try spraying contact cleaner or WD40 into the area by the plunger, I have done this and it has brought a few back to life after operating it numerous times by hand. Many give trouble because the corrode from lack of use
Same as the Carburettor model R6
Later 04/05 ones were upgraded
samsung
« Reply #2 on: 08 April 2015, 08:13:32 am »
Thanks for the advice.I've had the bike off the road for 18months,will pick up some contact cleaner today and give it a go. :)
