Date: 09-05-26  Time: 21:02 pm
Author Topic: Downpipe removal....Snapped things....  (Read 66310 times)
sinto
Re: Downpipe removal....Snapped things....
« Reply #25 on: 03 April 2015, 01:48:58 am »
Geez Paul, are you saving up bikes? There doesn't look like there is any space for spare parts though ;-)
anutz
« Reply #26 on: 03 April 2015, 08:03:41 am »
thanks all for the input - going to try the locked nuts method first, shall update soon...
Jules-C
« Reply #27 on: 03 April 2015, 08:49:34 am »
If it's snapped off more or less flush with the surface of the clamp my preferred method is nuts like these eBay items 19053881990 or 281390078158.  Saves having to do any drilling.  Never found any stainless ones tho.
anutz
« Reply #28 on: 03 April 2015, 09:01:23 am »
i think thats whats happened, i have just the "Nut" that snapped off in the socket - and its flush with the clamp - so fair bit left.....
Might take a look at these nuts before i try remove anything - and the rivet nuts seem a good idea
Have you got ebay links, i cannot seem to find those items?
anutz
« Reply #29 on: 03 April 2015, 09:06:09 am »
OK found them.....sleeve nuts.....
They look ok, do you need to drill the clamp holes?
YES
anutz
« Reply #30 on: 03 April 2015, 09:32:29 am »
Regardless of what i do - is this likely to be an MOT issue - assuming i either get them out and replaced or use some magic nuts, if its clamped properly etc...
« Reply #31 on: 03 April 2015, 09:48:24 am »
As long as the exhaust is not blowing you will be ok.....if whats left of the thread is not damaged the sleve nut is the best /easiest way to go....use this method on my thou last year, will see if I can find the piccies.....oh, yes, you will have to drill the mounting flanges out a little, easy to do as soft like the nuts :rolleyes
« Reply #32 on: 03 April 2015, 10:01:35 am »
found them.hope they help
anutz
« Reply #33 on: 03 April 2015, 10:34:08 am »
What about using these, similar items mentioned earlier in the thread...
http://www.screwfix.com/p/joint-connector-nuts-m6-x-17mm-pack-of-50/83521
Still need to drill the clamps...
In your pictures, you seem to have a screw on stud extender....is that what they are called?
« Reply #34 on: 03 April 2015, 11:57:30 am »
What's the one fazersharp ?
I was refering the the post before mine, this one
This was talked about not so long ago, what you need is a ----- damit I cant remember the name but it has a long shaft before its a nut and I think you drill out the bracket a little to accommodate the nuts shaft.Im sure somone will be along shortly and tell you properly
Edit------- they are called rivet nuts,
Search this forum for "snapped studs" you are not alone
Good memory, Sir.  Here's the thread you need http://foc-u.co.uk/index.php/topic,12338.msg137697.html#msg137697
This bit
So yes they are called rivet nuts and you do have to drill the clamp hole wider to acomadate them, or use sleave nuts or stud extender like has been mentioned. I would not risk getting the stud out, consider the snapped nut a warning
« Reply #35 on: 03 April 2015, 12:06:40 pm »
RED 98
Why did you use that extra spacer between the clamp and the bolt, was your stud extender poking above the clamp and is that extra spacer bigger than the stud extender so it sits over the part sticking above the clamp ?
« Reply #36 on: 03 April 2015, 12:07:10 pm »
made them myself, just a bit of tube that I cut to length and then ran a tap down.....those screwfix connectors might work, they wont be threaded all the way down though..cut the head off and run a tap down, should work and screwfix are open today....will depend on how much broken stud you have left weather you have to open up the flange holes or not, wont br much bigger,2mm at most I would of thought ..
« Reply #37 on: 03 April 2015, 12:11:10 pm »
RED 98
yes, thats right fazersharp.the break in the stud was more or less inline with the flange.extra spacer just slips over the extension tube...might of been able to trim the extension tube a bit more and done without it but not much broken stud to play with....been on the bike for about a year now and no problems, much easier than boring it out  ;)
sinto
« Reply #38 on: 03 April 2015, 12:34:03 pm »
I've never heard of rivet nuts till now, and managed to get any stuck bolts out using the method I said before, maybe I've been just lucky? but always keen to learn other ways in case it's needed :-)
Jules-C
« Reply #39 on: 03 April 2015, 01:52:37 pm »
Didn't need to drill the clamp with the nuts I found on eBay. They are a snug fit inside Motad clamps.  Original pipes clamps might have smaller diameter holes that need drilled?
anutz
« Reply #40 on: 03 April 2015, 02:33:26 pm »
well, i tried to remove it and its sheared off flush with the head...
I don't think i can get to it to drill it properly....
What about taking the head off the engine......
« Reply #41 on: 03 April 2015, 03:20:03 pm »
Be easier to remove front wheel and forks......if you remove the head you'll need a new gasket,£30 when I last bought one.....
anutz
« Reply #42 on: 03 April 2015, 03:43:59 pm »
yep i thought of that once i posted - so thats my next job :)....what a nightmare!
« Reply #43 on: 03 April 2015, 04:19:57 pm »
AHHHHHHHH !!!I warned you TWICE  :\
Quote
Quote
Yeh thats the one !!, if the fella does that then he does not run the risk snapping the stud trying to get it out.
Its just from knowing myself, I have learnt with things like these that I am Frank Spencer and I know that I will beak it.
Sorry fella  :'(
Paulfzs
« Reply #44 on: 03 April 2015, 04:20:53 pm »
yep i thought of that once i posted - so thats my next job :) ....what a nightmare!
which cylinder is it on?
on mine in the pic above it was #2, looking at it head on its 2nd from the right and i know you can get to both bolts on the middle 2 with a drill just takes a bit of origami with the drill to get it in.
failing that as above remove the forks
anutz
« Reply #45 on: 03 April 2015, 04:36:31 pm »
i wish i had listened to you Fazersharp...but i thought "i will be gentle...it will be ok....." it was not...i was not being rough with it, they just are so brittle!
Trying with a stud extractor kit now and then will give up and see about drilling it out completely.....
Paulfzs - its the 2nd cylinder so to the left of middle when sat on the bike.....just not enough room for my drill as wheel etc in the way
Can't stop laughing!
 :rollin
sinto
« Reply #46 on: 03 April 2015, 05:15:01 pm »
 :rollin
But surely anutz is a lot easier to remove the front end as apposed to the removal of the engine?
anutz
« Reply #47 on: 03 April 2015, 05:21:57 pm »
OK so managed to wangle my way in with without the wheel having to come off, no luck with the stud extractor
SO im stuck now - either i mess around drilling it out and then tap it ( i have never done that, and have no kit i.w. tap and die )
Or i take the head off and take it to a shop to get sorted ( never taken the head off either but i can see disconnecting things might be easier than working on the bike as it is - on its center stand
Any other ideas or advice
sinto
« Reply #48 on: 03 April 2015, 05:44:35 pm »
I think you can hire tap and dye sets, maybe from HSS Hire or somewhere like that, maybe worth trying your local yellow pages?
Where abouts are you anutz?
Paulfzs
« Reply #49 on: 03 April 2015, 07:26:11 pm »
surely someone on here will have a set you can borrow.
drilling isnt hard tbh, it took me about an hour to drill mine starting at 2mm going up in .5's just be gentle dont snap the drill bit.
taking the head off you need to take the engine out, took me 2 days to get mine out lol theyre a pain!!
then itll be £100000000000 to get it drilled out.
do it yourself in under 2 hours no problem
