Date: 08-05-26  Time: 23:22 pm
Author Topic: k&n filter vibe issue  (Read 3617 times)
scoobie_paws
« on: 22 March 2015, 07:12:36 am »
Ok so i changed out the air filter from standard to k&n And it has made the bike really vibey. Always has the 6k buzz but now get vibes all thru the range. Any ideas why?
Wondered if it had made mixtures too lean but no idea if that would cause the vibes? Def increased acceleration so would like to keep it but making it uncomfortable to ride.
Any thoughts?
rhinoeli
Re: k&n filter vibe issue
« Reply #1 on: 22 March 2015, 07:47:35 am »
Did you have the carbs synced after the change?
scoobie_paws
« Reply #2 on: 22 March 2015, 04:39:27 pm »
nope just wacked it in
might be worth a look. always had bad buzz at 6k but rode around it
Davew
« Reply #3 on: 24 March 2015, 11:42:01 am »
that's interesting, as I have always had annoying vibe issues that I've mostly sorted.  Might check my airbox isn't causing vibes by padding the filter out slightly where it rests on the bottom of the box or something.
« Reply #4 on: 24 March 2015, 12:16:26 pm »
Does it rest on the bottom?
Davew
« Reply #5 on: 24 March 2015, 12:20:26 pm »
I mean the filter inside the box, not the box itself, sorry.  I wonder if the filter isn't a snug fit and is vibrating slightly.  I remember tightening the airbox up when I bought the bike which helped the vibes a little.
« Reply #6 on: 24 March 2015, 12:23:52 pm »
I meant the filter too, don't actually know if it touches the bottom of the air box, but a K&N is very snug and well fitting around the top so won't vibrate there.
Cheaper air filters can be ill fitting and loose in comparison.
Davew
« Reply #7 on: 24 March 2015, 12:35:43 pm »
OK, will have a look and see.  could well be vibrating from the top if it is loose I guess.
« Reply #8 on: 24 March 2015, 12:54:22 pm »
My old air filter I had for about a week which was crap had about 5mm of play around the top, but I never knew it was ill fitting until I put the K&N in, which fits absolutely perfectly.
