Date: 14-01-26  Time: 20:18 pm
Author Topic: What is this thing inside the front sprocket cover?  (Read 4162 times)
rhinoeli
« on: 20 March 2015, 05:42:08 pm »
What is this metal sheet thingy inside the front sprocket cover? Couldn't loosen 2 of the 4 screws, no impact driver at hand.
Picture attached.
ChristoT
Re: What is this thing inside the front sprocket cover?
« Reply #1 on: 20 March 2015, 06:02:57 pm »
It's to do with the clutch
rhinoeli
« Reply #2 on: 20 March 2015, 06:12:35 pm »
I don't think so. I am talking about that large metal thingy fitted by 4 Phillips screws. Does it cover something or is it just to make the cover more rigid?
« Reply #3 on: 20 March 2015, 06:19:54 pm »
Its sound proofing and only the early bikes have it and there i no one on earth who can remove those screws see here http://foc-u.co.uk/index.php/topic,10124.msg105271.html#msg105271 bottom two posts
« Reply #4 on: 20 March 2015, 06:30:04 pm »
It does have one useful feature: it prevents the old 9mm self-loosening sprocket nut from falling off the end of the drive shaft. :lol
rhinoeli
« Reply #5 on: 20 March 2015, 06:32:24 pm »
That really is a good feature. I hope I won't need it.
wraith600
« Reply #6 on: 30 April 2015, 12:38:47 am »
got mine off was a pain though
« Reply #7 on: 30 April 2015, 06:28:37 am »
I still really like that particular post, i might lube the bearings up again at the weekend if it's not snowing or a monsoon, it makes a huge difference and it's not something you would ever think of doing normally.
I would advise everyone to give it a go  :thumbup
Paulfzs
« Reply #8 on: 30 April 2015, 08:03:33 am »
as do i, i might try it myself.
« Reply #9 on: 30 April 2015, 08:15:11 am »
So what year did they stop fitting that plate and what is behind it - any felt or somthing or just air
« Reply #10 on: 30 April 2015, 08:21:02 am »
It is a damper according to Yamaha and they stopped using them in the Foxeye models
I usually put them back into any Foxeyes I've worked on as they stop the sprocket nut falling off completely which stops the sprocket falling onto the threads and losing drive.
Deefer666
« Reply #11 on: 30 April 2015, 09:09:09 am »
They were to stop the Front sprockets coming off if the nut failed, it baffles me as to why you would take it off as they are not designed to be removable
« Reply #12 on: 30 April 2015, 09:23:39 am »
To properly clean all around,
rhinoeli
« Reply #13 on: 30 April 2015, 10:07:03 am »
If they were aware of the sprocket nut problem back in 1998, why did Yamaha not solve it by using a nut like the new 12 mm one?
Also, why did they discontinue to install these plates in foxeye models?
« Reply #14 on: 30 April 2015, 10:30:17 am »
They were never designed to stop sprocket nuts falling off, but dampers to reduce sprocket noise.
I only noticed its that it may stop the sprocket nut falling off after it happened to my foxeye.
The damper was in the cover of my sons 400 but not in the cover foxeye. The bolt holes are there, but not threaded.
On further inspection I noticed that it was very close to the shaft and would have prevented the problem of the nut falling away completely and allow, as in my own situation where the nut came off completely, the sprocket fell on to the threads and I lost all drive when overtaking.
