Date: 06-03-26  Time: 10:01 am
Author Topic: Sorry - another gearing question  (Read 2363 times)
Peasy
« on: 20 March 2015, 12:43:27 pm »
hi all, gen 1 1000
I understand the std gearing to be 16/44
I've been doing some cleaning etc and found that the previous owner had fitted a 17/45 combination.
Sorry, I still to this day can't get my head around gearing so please could someone tell me in simple terms what effects this gearing has?
Also I noticed that the chain has made marks on the rubber on the sides of the front sprocket where the rounds of the side plates seem to be touching it.
I like things standard too so probably swap back to standard but would like to gain an understanding.
Cheers
Lewis
Falcon 269
Re: Sorry - another gearing question
« Reply #1 on: 20 March 2015, 02:07:47 pm »
I'll try to keep this simple.  Like me.
Reducing the size (number of teeth) on the front sprocket lowers the gearing, which means higher engine revs for a given road speed but quicker acceleration.  Also, it will increase fuel consumption at cruise speeds.
You have a larger front sprocket, though, which on its own would raise the gearing and give the opposite effects to the above.
However, you also have a larger rear sprocket than standard which changes things again.  Stay with me. :)
Fitting a larger rear sprocket (more teeth) lowers the gearing, the same as fitting a smaller front sprocket.  In your case, the PO has done a bit of each.
The extra tooth on the front sprocket has a greater overall effect than the single extra tooth on the rear, meaning you bike is higher geared than stock.
In theory, you have a little less acceleration on tap but cruise rpm for a given speed will be lower, hence marginally better fuel economy.
Usually if owners change the gearing on a Gen 1, then drop a tooth at the front - and possibly go up one or two in the rear - to make bike more responsive.
I've never tried lowered gearing on mine as I'm perfectly content with how it performs on stock cogs. :)
« Reply #2 on: 20 March 2015, 02:39:23 pm »
Mike,  can you repeat that again for me please, was with you up until you said "simple"  :lol
Peasy
« Reply #3 on: 20 March 2015, 04:03:15 pm »
Thanks Mike, I think I get it now.
Back to standard cogs for me I think.  :D
Falcon 269
« Reply #4 on: 20 March 2015, 04:41:33 pm »
Well done ... I lost meself just before the full stop after simple :lol
pilninggas
« Reply #5 on: 20 March 2015, 09:10:50 pm »
surprised noones added:
www.gearingcommander.com - excellent way to model different gearing configurations.
