Date: 12-05-26  Time: 01:05 am
Author Topic: Chain replacement  (Read 5385 times)
Sannox
Chain replacement
« on: 18 March 2015, 10:45:28 pm »
41,001 miles on my 2002 foxeye and it's time to replace the original chaine, love scottoilers :-)
My question is, can you fit an endless loop chain on or do you need to use a riviter tool?
Ruby Racing
Re: Chain replacement
« Reply #1 on: 18 March 2015, 11:49:48 pm »
If you drop your swing arm out you can fit an endless chain.
rhinoeli
« Reply #2 on: 19 March 2015, 09:05:40 am »
Did you ever had the swingarm off? If not, now it's a good time for a clean and greasing. If you can not buy an endless chain I suggest you to rivet it at your workbench vise, much easier than after installed on the sprockets.
« Reply #3 on: 19 March 2015, 09:24:43 am »
Yep Scottoilers are great, I replaced mine after 42000 miles.
Buy an endless chain and drop the swinging arm to fit it
It will give you a chance to inspect the suspension linkage bearings at the same time.
Sannox
« Reply #4 on: 21 March 2015, 01:25:15 pm »
Good call on dropping the swing arm out, cheers guys :-) Not dropped it out and I know I need to check over the shock linkage as well so now being a good time as I've got the bike stripped to do some other work, like brake pads, fork oil, respray, coolant change, check steering head bearings after replacing them a while back etc, you know how it is :-)
Ruby Racing
« Reply #5 on: 22 March 2015, 12:48:33 am »
Dropping the swing arm is really straight forward and pretty quick. You could do it with the rear wheel in place, but much easier with it removed.
Sannox
« Reply #6 on: 16 April 2015, 10:46:39 pm »
Dropped the swing arm out tonight, rear wheel out 1st, then back in so when I undid the swing arm bolt, I didn't tip the bike :-) all came out without any problems, should have dismantled the lower shock bracket 1st though, but wasn't a problem, all cleaned up, no pitting on any of the shafts though the grease was drying up, so good call to drop out the swing arm, also gives me a chance to get it all clean under there as well as change the rear brake pads.
Quick call round to M&P tomorrow for a gold X ring chain and sprocket set for £97 and will be all back together tomorrow night :-)
Front forks oil change after that.
Sannox
« Reply #7 on: 16 April 2015, 11:02:11 pm »
All stripped.
Chris
« Reply #8 on: 17 April 2015, 05:45:00 am »
Nice!
Much easier to get some cleaning done with all that faffery out the way.
Chris
Sannox
« Reply #9 on: 17 April 2015, 07:51:25 pm »
First time I've had the swing arm out Chris, was easy enough, can finally clean the shock too as well as everything else :-) Resprayed, again, metallic black, they never did black on the foyeye model for some reason, new original decals to go back on too.
Chris
« Reply #10 on: 17 April 2015, 09:13:11 pm »
looking forward to the finished pictures!
Think that's next winters job for me, remove swing arm, get it powder coated gloss black, new bearings etc.
Chris
Sannox
« Reply #11 on: 19 April 2015, 10:05:31 am »
There is a pic of this from when I origianlly did the respray in the show me your Fazer bit, but will bung it here, this is from 2 years ago. Was never happy with never being able to get the engine clean, however, I have a plan.....
« Reply #12 on: 19 April 2015, 11:57:37 am »
Thought M&P only supplied split chains?
« Reply #13 on: 19 April 2015, 01:19:37 pm »
Usually with a soft link
Sannox
« Reply #14 on: 04 May 2015, 12:28:01 am »
You're right, split link, to my surprise, when I opened the box, however, seems all chains are supplied like that unless OEM and to be honest, I wanted a chain that lasts even longer than the 41k miles the last one did :-) Got some X ring gold chain and the scottoiler should see it past another 41k
