Date: 11-05-26  Time: 12:41 pm
Author Topic: Seized rear brake caliper  (Read 6247 times)
fazersteve
« on: 05 February 2012, 06:04:48 pm »
Hi all from a very cold Inverness,
Prior to taking my bike off for the winter I set about cleaning my brakes.Front both fine but the rear had a stuck piston.
Last week left the caliper with a mechanic friend to blow piston out with compressed air.The bad news is the piston is seized solid and will not move.
So do I have any other options apart from a second hand caliper.
Fazer Jake
Re: Seized rear brake caliper
« Reply #1 on: 05 February 2012, 06:26:50 pm »
i got mine out with mole grips, u have to be extremely careful though not to damange the piston, unless your buying new ones.
solorider
« Reply #2 on: 05 February 2012, 06:27:34 pm »
You could reconnect the calipers and bleed it,then clamping the good piston pump the piston out,hydraulic pressure should shift it
dogruff
« Reply #3 on: 05 February 2012, 06:34:26 pm »
Haven/t suffered this problem yet,but apparently its a common Fazer problem.My old sumitomo's seized badly once but blew out okay,Sounds like a replacement caliper to me.Check this site as i think the Fazer 1000 is a straight swap,but a different type of caliper,therefore less prone to permanent seizure.If the piston is seized flush there is very little you can do.If you can catch a good edge Vise grips may release it,if you twist, but will damage the piston.
fazersteve
« Reply #4 on: 05 February 2012, 06:35:11 pm »
Hi,
Have tried clamping and using hydraulic pressure but just won't budge.
fazersteve
« Reply #5 on: 05 February 2012, 06:37:11 pm »
Are the caliper from the 1000 just a straight swap.
dogruff
« Reply #6 on: 05 February 2012, 06:55:22 pm »
Someone with more knowledge than i have will answer,but i'm sure i read it somewhere.Problem is i've owned too many bikes over th years and my old brain can only hold a certain amount of data.The problem is just finding the right model ie Gen 1 FZ1 FZR!!!.
davec
« Reply #7 on: 05 February 2012, 07:35:17 pm »
Yeah, they are a straight swap apart from having to slightly modify the caliper bracket.You just need to cut/file a small part of it away so the bolt holes line up. You'll need a caliper from a 2001-2005 FZ1.
kebab19
« Reply #8 on: 05 February 2012, 07:43:18 pm »
Covered extensively, even on this new site. FZS1000, TRX850 & YZF750 rears fit
http://foc-u.co.uk/index.php/topic,942.msg6067.html#msg6067
fazersteve
« Reply #9 on: 05 February 2012, 08:20:29 pm »
Thanks to all who replied.
