Date: 24-04-26  Time: 18:33 pm
Author Topic: Clutch dragging when cold  (Read 3027 times)
silver-sloth
« on: 14 March 2015, 11:44:31 am »
OK, starting my "second life" on FOC-U with a cry for help!
Bike is a 2003 FZS1000
I recently put new clutch plates in and also a new clutch cable (also did an oil change at the same time).  When the bike is warmed-up, the clutch is fine, but when its cold, the cable has tightened-up taking the play out of the run and the clutch draggs really badly and won't fully disengage.  Once it warms up after a couple of miles, the cable slackens-off to give the correct play and the clutch works fine again
Any suggestions or assistance will be much appreciated.
Cheers,
Jon
Falcon 269
Re: Clutch dragging when cold
« Reply #1 on: 14 March 2015, 02:23:49 pm »
Hi and welcome back. :)
Genuine Yamaha clutch cable or pattern part?  The latter have a reputation for causing clutch adjustment issues.
b1k3rdude
« Reply #2 on: 14 March 2015, 09:15:29 pm »
Also
check the following -
- the clutch basket for wear on the finger where the friction plates rest against it.Will cause clutch drag, (because the clutch isn;t fully disengaging) which can then make it hard to find neutral.
b1k3rdude
« Reply #3 on: 14 March 2015, 09:16:02 pm »
Also check if the end-plug is missing from the clutch main-shaft -
- http://foc-u.co.uk/index.php/topic,13825.0.html
redrat
« Reply #4 on: 14 March 2015, 11:37:53 pm »
I had this plug problem on one of mine before aswell.
silver-sloth
« Reply #5 on: 15 March 2015, 09:29:25 am »
Thanks for the suggestions folks, much appreciated.
Jon
silver-sloth
« Reply #6 on: 22 March 2015, 11:55:17 am »
Ignore this post - now sussed it! (Don't know how to delete the post, so mods, please feel free to delete it - Ta)
Jon
