Date: 15-03-26  Time: 04:02 am
Author Topic: A couple of headlight questions - 2008 FZ6 S2  (Read 5909 times)
WhiteZer
« on: 11 March 2015, 06:03:04 am »
Following my ignition fix and the relevant tear down of the front of the bike, I noticed a couple of things regarding the headlight on my bike, can anyone answer the following:
There was a single yellow wire taped to the headlight main bulb loom, not going anywhere.  Any ideas what this could be?
No bulb in the parking/side light hole.  Should there be?
Thanks.
Grahamm
  • Global Moderator
Re: A couple of headlight questions - 2008 FZ6 S2
« Reply #1 on: 11 March 2015, 11:46:46 am »
Looking at the wiring diagram in the Haynes manual it appears to be for the headlamp flasher switch.
Quote
Err, probably!
WhiteZer
« Reply #2 on: 11 March 2015, 07:32:11 pm »
Thanks for the info.
Odd about the cable, I'm sure my flasher switch works!  I'll try it again.
Also, it'd just had an MOT when I purchased it, but no bulb!
Now off to the shed to try the flash!
chaz
« Reply #3 on: 11 March 2015, 08:44:04 pm »
re. side light, as the headlight is on all the time maybe the tester missed it? it's on till you start the engine and if you turn the key anti-clockwise past the off to park, also my Flash doesn't work through lack of use, I never use it but did try it a few years ago.
WhiteZer
« Reply #4 on: 12 March 2015, 05:49:09 am »
I'll get a bulb and see if the sidelight works this weekend.
With regards to the headlight flasher, that works fine!
Update - It looks like the yellow cable could be the connection for the Main Beam indicator.
Update2 - It was.  It had snapped away from a small connector.  Connected it back up and away we go.
Grahamm
  • Global Moderator
« Reply #5 on: 12 March 2015, 10:03:22 pm »
Ah, yes, that's the other end!
Glad you got it sorted :thumbup
