Date: 08-05-26  Time: 10:21 am
Author Topic: clutch problem...  (Read 5365 times)
Paulfzs
clutch problem...
« on: 10 March 2015, 05:52:04 pm »
ok so i had a problem with my clutch last week where it suddenly went slack...
replace clutch cable and it was fine untill today when i went out it suddenly went slack again.
adjusted on the handlebars to its near max adjustment, when i looked at where the cable goes into the sprocket cover it appears there is a fair bit of play in the cable it moves up and down freely even near max adjustment.
cable is correct one.
stevie-g1968
Re: clutch problem...
« Reply #1 on: 10 March 2015, 08:03:59 pm »
Do you have a haynes book of lies?    Have you adjusted the mechanisum behind the rubber bung on the sprocket cover?
Paulfzs
« Reply #2 on: 10 March 2015, 08:05:53 pm »
not sure how?
saw mention of undoing the nut then turning the screw but i havent tried it, might have to now.
spanner or socket?
Triggergee
« Reply #3 on: 10 March 2015, 08:22:32 pm »
You'll need a bent spanner and a screw driver, got to loosen it with the spanner then adjust with the screw driver whilst holding the spanner in place. Then tighten with the spanner whilst holding the screw driver in place. Screw the adjuster on the clutch lever in nearly all the way before tightening at the sprocket cover end then fine tune with the adjuster on the lever
Paulfzs
« Reply #4 on: 10 March 2015, 09:06:56 pm »
awesome thanks, i have some poverty spanners that i can bend
« Reply #5 on: 10 March 2015, 09:15:07 pm »
It will probably loosen with a crack and frighten the crap out of you   :lol
stevie-g1968
« Reply #6 on: 10 March 2015, 09:34:49 pm »
 :lol :rollin
« Reply #7 on: 10 March 2015, 09:40:27 pm »
You need quite a deep angled ring spanner.
Paulfzs
« Reply #8 on: 10 March 2015, 10:31:02 pm »
deep ring...
ill give it a go :D
« Reply #9 on: 10 March 2015, 10:50:36 pm »
You can get away with a socket, tighten the inner screw up then back off a quarter of a turn then tighten the outer nut, but judging it right is a bit of an art.
Much more precise with the right tools.
Paulfzs
« Reply #10 on: 11 March 2015, 12:18:52 am »
will give it a go :D
sprocket cover on or off?
ive seen the bit i need to adjust but cant remember if its inside the case
« Reply #11 on: 11 March 2015, 02:05:14 am »
Rubber cap off of sprocket cover will reveal the nut.
Paulfzs
« Reply #12 on: 11 March 2015, 11:07:06 am »
i dont have the rubber cap on i never had one on either engine.
« Reply #13 on: 11 March 2015, 12:23:55 pm »
Hopefully it does only need adjusting, but if the cable went slack suddenly it may be the gizmo inside that converts a pull on the cable to a push on the clutch rod is collapsing.
The bearings can get rusty which is more likely if the rubber cap isn't there to keep rain and road salt at bay.
To investigate, you'll need to take the cover off and undo the two screws holding the mechanism on. This isn't easy as they're tight and the heads are about as hard as ripe brie.
« Reply #14 on: 11 March 2015, 12:32:15 pm »
Paulfzs
« Reply #15 on: 11 March 2015, 01:34:14 pm »
cheers guys and thanks fazer rider, will go take a look when i feel like giving away more free time to the borderline moneypit of a fazer i own lol.
Paulfzs
« Reply #16 on: 14 March 2015, 04:47:52 pm »
coming up to a roundabout i had no clutch at all so i was stuck in 1st gear, managed to negotiate it in 1st and pull over, found the problem, the adjuster in the case was loose!
had to buy a screw driver from a petrol station to tighten it up but it came loose again a few times as i couldnt do the nut up due to lack of tools.
His Dudeness
« Reply #17 on: 14 March 2015, 07:52:35 pm »
You found the problem alright. It was the dumbass that replaced the cable :lol Only joking  :lol
Paulfzs
« Reply #18 on: 14 March 2015, 09:39:03 pm »
i thought to myself nevermind its an easy fix.. then remembered i threw the old cable in the bin when it didn't even need changing...
in my defence i had no idea the bit in the case was an adjuster.
His Dudeness
« Reply #19 on: 14 March 2015, 10:34:46 pm »
 If you fix your own stuff inevitably something is going to go wrong at some point you just have to learn from it.
