Date: 23-04-26  Time: 11:31 am
Author Topic: Engine Fault Light Help  (Read 3334 times)
Grayo
« on: 05 March 2015, 10:29:51 am »
I've just had the yellow engine fault light come on and the handbook says it's an electrical fault. (2008 FZ1)
Is this a common problem ? If so, does anyone know where I should be looking or does it need to go to the dealer to be sorted.
Thanks in advance.
slappy
Re: Engine Fault Light Help
« Reply #1 on: 05 March 2015, 11:58:28 am »
Do  you get an error code as well?
Grayo
« Reply #2 on: 05 March 2015, 03:13:33 pm »
No error code.
I've had the battery on charge for an hour so and now the light has gone out.
Would a battery problem cause the light to come on ?
slappy
« Reply #3 on: 05 March 2015, 07:19:37 pm »
A low battery could have caused it, not totally sure about this but I think the ecu senses the low voltage and turns off non essential stuff, this then causes the engine light to come on.
I have also heard it can happen from a loose connection, if you keep the battery charged up and it happens again check all the connections for tightness/corrosion.
Grayo
« Reply #4 on: 05 March 2015, 09:21:34 pm »
Ok, thanks for that.
noggythenog
« Reply #5 on: 05 March 2015, 09:36:10 pm »
Check this out Grayo, an old post regarding how to use the diagnostics tool and find the codes.
http://foc-u.co.uk/index.php/topic,5766.msg50597.html#msg50597
I had the light come on once, i was gutted but i took it out for a spin and it was fine....next day i go out to ot and the light no longer came on....but i have an intermittent starting issue which i still need to rectify (been sayi g it for about 4 months now :rolleyes ) which is most likely a dodgy connector somewhere......i have just got some contact cleaner and dielectric grease so i can go through as many connectors as i can get to......fingers crossed it'll sort my issue.
[size=78%]Ive never done contacts before so not sure what to expect but if any of the connectors look particularly corroded then ill post up which ones coz the way i see it, could be inherrent and other bikes with simillar age/mileage could suffer the same. [/size]
Grayo
« Reply #6 on: 05 March 2015, 10:21:43 pm »
That's great, thanks Noggy. I turned the ignition on about an hour ago and the light was off. Think I'll order a new battery first and take it from there.
Grayo
« Reply #7 on: 07 March 2015, 05:50:15 pm »
I'm now sure it's a battery fault.
If I turn the ignition on when the battery is on charge the engine fault light is out.
As soon as I unplug the charger and turn the ignition on, the engine fault light comes on.
New Motobatt battery has been ordered.
Grayo
« Reply #8 on: 11 March 2015, 12:21:14 pm »
Just fitted the new battery and all is well again.
No engine fault light. :)
