Date: 22-03-26  Time: 06:40 am
Author Topic: Spinning Bolts....oh no  (Read 2716 times)
anutz
« on: 28 February 2015, 12:05:48 pm »
Hello!
So i have been getting to grips with my Fazer, 2001 FZS 600, i have managed to now get the fuel tank off and wanted to change the air filter, so this involves removing the fuel tank mounting bracket....well this is where the problem lies...
PROBLEM WAS ME - NO NEED TO TAKE OFF BRACKET - READ THE THREAD
One of the bots backed out fine, the other just spins freely in both directions... :eek
I can see the brackets are cheap and plentiful on known sites, so that is good....if i have to get a new one..
But the question is any tips on how i get this bolt out - if its a simple case of like any other then i shall spend the day on the internet  :)
Anutz
limax2
Re: Spinning Bolts....ho no
« Reply #1 on: 28 February 2015, 01:03:16 pm »
It sounds like the thread is stripped or the square nut that should be welded to the plate has come loose. Have a look under the plate at the nut and see if it turns when you turn the bolt. If it does, get a spanner or some pliers on the nut while you undo the bolt. The nuts are only welded on to ease assembly so you could just re-use it or replace it with a normal hex nut, preferably of the locking insert type.
If the nut is still welded on the plate then the thread on the nut or bolt must be stripped. You could try pulling up on the bolt while you undo it. If that doesn't work a last resort is to drill the head off.
Good luck with it.
RMT1983
« Reply #2 on: 28 February 2015, 01:04:53 pm »
there should only be 2 bolts mate, on up front by the forks to release the tank so it can pivot and 1 long bolt about 3 inch long that goes all the way through the mounting bracket...................
Scrap that...................... as he said! ^^^  :lol
anutz
« Reply #3 on: 28 February 2015, 02:10:54 pm »
Thanks both...
RMT1983 - got the tank off ok  :)
But i need to get the bracket off the frame so i can get to the air filter, there is a rubber cover that the tank bracket fixes in place...and its one of those bolts that is just spinning
If all else fails its angle grinder time .... :b
Anutz
« Reply #4 on: 28 February 2015, 02:36:35 pm »
You don't need to remove any brackets at all to remove the air filter???
Peel away the rubber cover, unscrew the air box lid and just take it out!
RMT1983
« Reply #5 on: 28 February 2015, 03:07:06 pm »
Since ive got one in bits I thought id have a nosey for you...........................
« Reply #6 on: 28 February 2015, 03:09:48 pm »
I've never had to remove that bracket before?
RMT1983
« Reply #7 on: 28 February 2015, 03:12:03 pm »
im sure if you just remove the side panels and unplugged the rubber flappy cover from either sides then yeah you could just flop it back a bit???
RMT1983
« Reply #8 on: 28 February 2015, 03:13:50 pm »
after scanning through my pics neither did I!!!
« Reply #9 on: 28 February 2015, 03:55:23 pm »
He's undoing the rubber back to front i reckon.
« Reply #10 on: 28 February 2015, 03:59:12 pm »
Like trying to take your trousers off over your head.  :lol
anutz
« Reply #11 on: 28 February 2015, 04:54:46 pm »
 :o  nufff said :)
K and N installed....
anutz
« Reply #12 on: 28 February 2015, 04:55:53 pm »
oh,
got the bolt sorted, ground the top off and then drilled out the screw from the bottom bracket - new one on the way
« Reply #13 on: 28 February 2015, 04:56:05 pm »
Well at least you know how to do it now. :rollin :rollin :rollin
