Date: 02-05-26  Time: 03:03 am
Author Topic: Help..........Damper rod removal  (Read 2882 times)
Rexr
« on: 21 February 2015, 05:32:31 pm »
Just stripping down my gen 1 1000 forks to put in new seals and have a wee problem I can't get the damper rod out any suggestions on this would be appreciated
fazed out
Re: Help..........Damper rod removal
« Reply #1 on: 21 February 2015, 06:15:41 pm »
  tape a 27mm socket to a piece of tube  then slide it down inside of forks after you taken spring out use a allen key at the bottom of forks  then you can undo  they arn't very tight
Rexr
« Reply #2 on: 21 February 2015, 07:17:36 pm »
Cheers will give that a go in the morning....
Rexr
« Reply #3 on: 22 February 2015, 03:29:42 pm »
Cheers for that Fazed-out......all sorted now......
