Date: 08-05-26  Time: 09:06 am
Author Topic: full throttle bogging down a bit  (Read 9487 times)
Paulfzs
« on: 17 February 2015, 01:59:47 pm »
title says it all..
full throttle bike bogs down but off the throttle a little its fine.
could this be down to the tps being out?
tps has been adjusted but not had time to test it yet.
standard exhaust
standard air filter.
not jetted as far as im aware.
stevierst
Re: full throttle bogging down a bit
« Reply #1 on: 17 February 2015, 04:07:16 pm »
Possibly tps. If it's not that, a good carb balance will do it the world of good.
It has some funny effects on engine behaviour carbs being out.
BBROWN1664
« Reply #2 on: 17 February 2015, 05:19:25 pm »
get the carbs balanced and reset the TPS once you have done that. Assuming the air filter is clean you will notice a difference but not as much as a freer flowing pipe and K&N would add.
FZS600's do not need rejecting with any (or all) of the mods mentioned above.
Paulfzs
« Reply #3 on: 17 February 2015, 06:32:59 pm »
tps done
carbs balanced today
so much more responsive but still bogging down a little at full throttle :/
« Reply #4 on: 17 February 2015, 06:57:39 pm »
TPS and carb balancing has a big effect at small throttle openings, getting them right makes the bike much smoother at low speeds... not much effect higher up the rev range though.
A new air filter might help. How many miles does it have on it?
I've a pet theory that the carb slides start to lose their teflon coating by about 50,000 miles. This means they can jam if the throttle is opened suddenly causing the bike to bog down, but if the throttle is opened gently the slide has more of a chance to move before the vacuum causes it to stick. Really need to poke a camera into the airbox to see if this explanation holds water though.
Paulfzs
« Reply #5 on: 17 February 2015, 08:50:54 pm »
the engines at 23,000 but the carbs will be 44k+ as far as im aware its the original carb.
i dont think it bogged down on the old 1999 engine though the 03 engine does seem tons faster but not at full throttle.
« Reply #6 on: 17 February 2015, 09:00:45 pm »
Did you check the air filter????? :rolleyes
Frosties
« Reply #7 on: 17 February 2015, 09:17:45 pm »
Possible coil pack due to the extra load......
« Reply #8 on: 17 February 2015, 09:56:42 pm »
Or the Rectifier/regulator, but he needs to check the normal service items first.
Paulfzs
« Reply #9 on: 17 February 2015, 10:14:04 pm »
well it has one :D lmao
« Reply #10 on: 17 February 2015, 10:18:05 pm »
After reading some of your posts I wouldn't be surprised if you had a Shredded Wheat fitted.  :lol
Paulfzs
« Reply #11 on: 18 February 2015, 12:13:49 pm »
im resourceful if nothing else lmao
i paid out for a carb balancer though!
« Reply #12 on: 18 February 2015, 05:57:51 pm »
Any chance of  paying out on a new Air filter, :lol :lol :lol
Paulfzs
« Reply #13 on: 19 February 2015, 12:21:39 am »
ordered it today :D
« Reply #14 on: 19 February 2015, 08:28:21 am »
 :thumbup :lol
thunderpantz
« Reply #15 on: 27 February 2015, 07:52:10 am »
I'd be inclined to check the plug caps. I had the same issue with mine, where at full chat about mid way through the rev range it would feel as if I'd hit a puddle of treacle. Ease off the throttle to about 3/4 and is fine. Changed the plug caps to some NGK SD05F and the problem is gone. Very happy me  :rollin
« Reply #16 on: 27 February 2015, 08:21:43 am »
4 x  NGK SD05F = £10.36 incl. postage
4 x OEM plug caps = £222.76 incl.postage
ShadowFox
« Reply #17 on: 19 July 2017, 12:47:31 pm »
Hi, Dan here. I'm new to the site but I had the same issue. Bought my fzs600 last week and it would not open up past half throttle. If I eased off it would come up to speed eventually but if I went past half throttle it was like I'd hit a wall. Anyways today I pulled the carb out and noticed a rattle. After opening up the float bowls I noticed in 3of the 4 bowls all the jets had fallen out. I mean off completely. Surprised it's been moving at all. Anyway I put it all back together and took it for a spin. Revs all the way under load now. I'd say it still could do with the carbs balancing but the main issue is fixed.
Disorderlypunk
« Reply #18 on: 19 July 2017, 01:12:00 pm »
£222 for 4 oem plug caps - great now i have to clean up the soggy toast i spat out in shock across my laptop
« Reply #19 on: 19 July 2017, 06:27:18 pm »
That was 2 years ago.
£230.24 now on AJ Sutton website.
Disorderlypunk
« Reply #20 on: 19 July 2017, 07:12:23 pm »
great now ive got to clean up fish and chips - god damn ketchup in my usb port aswell
[size=0px]NGK SD05F  on my watch list now for next week - [/size]
« Reply #21 on: 20 July 2017, 05:31:25 am »
https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR0.TRC0.H0.TRS0&_nkw=NGK+SD05F++&_sacat=0
celticdog
« Reply #22 on: 20 July 2017, 07:52:31 am »
+ 1 for NGK plugs  :thumbup
daviee
  • Guest
« Reply #23 on: 22 July 2017, 07:55:38 am »
try cleaning the carbs
Disorderlypunk
« Reply #24 on: 22 July 2017, 08:34:28 am »
i would definatly chance the £20 for new plugs and caps before attempting to remove the carbs for cleaning
honestly the ball ache is unbelievable and there is nothing wrong with new plugs now and again
and redex does not constitute a carb clean. - even redex themselves dont mention carbs but so many fall for it
