Date: 09-05-26  Time: 13:37 pm
Author Topic: Spark plug change  (Read 5338 times)
helmetvonthrob
Spark plug change
« on: 15 February 2015, 01:01:35 am »
Is there a how-to anywhere for this?
Failing that does anyone have  preference; from above (airbox off) vs. from the side (drop the rad. etc.)
chaz
Re: Spark plug change
« Reply #1 on: 15 February 2015, 03:00:44 pm »
theres a bloke on youtube who has a video on changing the plugs in a FZ6 its in 6 parts takes longer to watch than it does to change the plugs, just done mine, I took the radiator of as I was renewing the coolant, there's two bolts holding the rad on 3 if you remove the bracket, 4 holding the fan to the radiator (couldn't find where connector was), I was repainting the rad and front of engine while on with it, you need the box spanner that comes with the bike to reach the plugs, and I had to move the throttle cable to get to number 1? Left hand side as sat on bike, slacken the lock nut on it and the bracket is slotted so it slides out.
I put all the bolts into thier own yogurt pot and wrote where it went as I tend to forget after a few days now?
make sure the numbers on the leads are ok and thats about it, if you have an airline blow the plugs after taking the caps off incase any dirt or water has got in, non in mine.
acid drop
« Reply #2 on: 15 February 2015, 03:12:25 pm »
 From the side and drop the rad
helmetvonthrob
« Reply #3 on: 15 February 2015, 04:33:58 pm »
theres a bloke on youtube who has a video on changing the plugs in a FZ6 its in 6 parts takes longer to watch than it does to change the plugs.
Watched it.... I was suicidal by the end of it!
Does it also mean taking off the fairing?
chaz
« Reply #4 on: 16 February 2015, 02:31:42 pm »
no fairing on mine?
Grayo
« Reply #5 on: 16 February 2015, 03:22:32 pm »
No need to take the fairing off (unless you have fairing lowers then they will have to be removed) but as has been said, you will need to drop the rad.
