Date: 01-05-26  Time: 14:27 pm
Author Topic: Caliper Piston Removal  (Read 4162 times)
Phil TK
« on: 02 February 2012, 11:03:25 am »
It looks like I've got a sticky or seized piston on one of my front calipers so I'm going to take both the calipers off and get all the pistons out for a good clean up. It's not a problem, I usually clamp 3 of the pistons and pump air using a foot pump into the caliper to blow out one piston, clean it up, put it back in and then do the other three similarly. But, for the life of me I can't remember how I used to connect the pump into the banjo bolt hole, I have a vague recollection of using a schraeder valve (from an inner tube) and a football inflator (or was it a 'bic' plastic pen cap) but can't imagine how. Somebody who has done this will know what I mean, I'd be grateful if someone could remind me. Cheers
DryRob
Re: Caliper Piston Removal
« Reply #1 on: 02 February 2012, 11:41:41 am »
Have you got a track pump? the shrader adapter on one might fit directly over the nipple? fnarr fnarr etc
I took the nipple out and wrapped abit of innertube around the end of a compressor gun and just held it in place, bit awkward though.
phil on a fazer
« Reply #2 on: 02 February 2012, 01:15:09 pm »
I've done in a few times but i use a compressor and take all the pistons out at once.(use a bit of wood in the middle and just watch the pressure ain't to high) I use an old schreader valve in where the bleed nipple goes. (i think, its been a while and you've got me thinking now???)
tommyteeman
« Reply #3 on: 02 February 2012, 01:15:40 pm »
I just use my "dust blower gun" attachment and the pistons fly out, no need for a good seal between gun and bolt hole. LAst time I did mine the pistons showed very little wear (@20.000 miles), but did renew all seals while I was there.
...sorry just reread your post there and see your using a foot pump, decent seal prob necessary then  :) . Compressors are great bits of kit and worth having, use mine all the time.
phil on a fazer
« Reply #4 on: 02 February 2012, 04:24:53 pm »
sorry to hijack the thread but where did you get your seals from? I'm a bit unsure about using non genuine ones?
tommyteeman
« Reply #5 on: 02 February 2012, 04:45:54 pm »
iirc wemoto
