Date: 14-01-26  Time: 12:38 pm
Author Topic: FZS1000 Clocks  (Read 4921 times)
bigbluebear
FZS1000 Clocks
« on: 02 February 2015, 02:18:57 pm »
I am looking at buying a set of speedo clocks to replace my existing ones....my old clocks are measured in KPH and have been fitted with some kind of modification gizmo to return them back into MPH.....Focced knows where and what this modification actually is but keen to get back to standard MPH clocks.
Does anyone know if these can be fitted as a direct replacement without the existing or any modifications etc
nickodemon
Re: FZS1000 Clocks
« Reply #1 on: 02 February 2015, 04:52:27 pm »
You will have a speedo convertor fitted.
http://www.ebay.co.uk/itm/Speedo-Conversions-KMH-to-MPH-/111373393344?pt=UK_Motorcycle_Parts_13&hash=item19ee5f1dc0
It fits to the end of your speedo cable and into the back of the clocks. If you want to change the clocks to mph ones, you simply take the old clocks off and unscrew the speedo convertor. Refit the speedo cable to the mph clocks. Simples :)
Tmation
Re: FZS1000 Clocks
« Reply #2 on: 02 February 2015, 05:04:06 pm »
I thought we have an electronic speedo, as in no cable.
bigbluebear
Re: FZS1000 Clocks
« Reply #3 on: 02 February 2015, 05:24:40 pm »
Cheers Nick
nickodemon
Re: FZS1000 Clocks
« Reply #4 on: 02 February 2015, 05:33:03 pm »
You might be right, as i cant recall. Too many bikes in the garage! If it is an electronic speedo it will have one of these plugged in  -http://www.ebay.co.uk/itm/Speedo-speedometer-converter-chip-E-SVA-IVA-KMH-to-MPH-CARTEK-CK-UN-09-/380258508684?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item58892c5f8c
Same principle applies. Un plug and change clocks :)
Re: FZS1000 Clocks
« Reply #5 on: 03 February 2015, 12:46:26 am »
Remove the seat and remove the right side panel (the one under the seat). The speedo sensor lead is located under this panel, most likely there is a speedo healer plugged into the loom somewhere around there.
keithfzs1000
Re: FZS1000 Clocks
« Reply #6 on: 03 February 2015, 08:15:27 am »
 ;) ;) i am replacing my mph clocks soon to aftermarket ones if you need to source some. Approx 30000 on clock no issues with them at all
will be flea baying them for around 100, fellow foccer 90 posted to your door.
bigbluebear
Re: FZS1000 Clocks
« Reply #7 on: 03 February 2015, 09:21:13 am »
Thanks, which after market ones are you going for
keithfzs1000
Re: FZS1000 Clocks
« Reply #8 on: 03 February 2015, 09:47:14 am »
http://www.ebay.co.uk/itm/LCD-Digital-Speedo-Handle-Bar-Risers-In-One-Streetfighter-Dash-Tacho-Gsxr-/111450105028?pt=UK_Motorcycle_Parts_13&hash=item19f2f1a4c4
but needs a billet yoke as they dont fit the R1 due to mounting measurements of risers
got the speedo just waiting for yoke to be manufactured
bigbluebear
Re: FZS1000 Clocks
« Reply #9 on: 16 February 2015, 04:27:21 pm »
Cheers...that's exactly where it was....now fitted with a new mph clocks
JoeRock
Re: FZS1000 Clocks
« Reply #10 on: 16 February 2015, 07:12:58 pm »
Still got the speedo healer fella?
bigbluebear
Re: FZS1000 Clocks
« Reply #11 on: 16 February 2015, 07:26:15 pm »
Yes selling the kph clocks too
