Date: 24-04-26  Time: 13:59 pm
Author Topic: Wiring in a Satnav.  (Read 9157 times)
Grayo
Wiring in a Satnav.
« on: 30 January 2015, 09:18:01 am »
Anybody help with how I should wire in a Satnav to my FZ1 ?  I've got a Garmin Zumo 390LM and ideally I would like it to be switched on and off with the ignition. All advice greatly appreciated.
Cheers, Grayo.
Exupnut
Re: Wiring in a Satnav.
« Reply #1 on: 30 January 2015, 05:44:12 pm »
Mine is wired straight to battery.  Make sure it's fused and u will be fine as it won't draw power unless u leave the satnav in the mount.
Grayo
« Reply #2 on: 30 January 2015, 09:28:03 pm »
Ok, thanks.
PaulSmith
« Reply #3 on: 03 February 2015, 10:58:00 am »
I wired in a cigarette lighter socket as per Pat's site: http://www.cartestsoftware.com/fz1/cigarettelightersocketinstallation.html which I mounted (facing down) to the coolent filler bracket under the right hand side dash fairing. It is on a relay with the sidelights so is powered with the ignition and is completely out of sight unless you go looking for it, but falls easily to hand when you know it is there.
slap
« Reply #4 on: 25 February 2015, 08:04:40 pm »
Hi, my garmin is wired upto my rear light (+) with a in-line fuse & earthed to a nearby frame screw using a "scotch block" for the live feed from the rear light. I used a car type cigarette lighter socket hid in the space in the fairing at side of the rear seat. I ran the mini USB cable under the tank & upto the yolks where my Satnav mount is. The cigarette socket has now been replaced by a garmin voltage converter as the Slovakian bad weather got into the lighter socket & blew the plug.
nsr500v4
davey boy
« Reply #6 on: 04 March 2015, 10:15:15 pm »
You can wire an automotive relay in and mount it on the rear sub frame in the seat shroud just wire the switced terminal to the licence plate light
bigralphie
« Reply #7 on: 05 March 2015, 01:22:13 pm »
The new Garmins have a fused auto sensing voltage step down converter built into the power cable
 you can go straight to battery or take a live from a more convenient point (lights etc)..
relay always a good shout
Grayo
« Reply #8 on: 08 March 2015, 04:25:37 pm »
Relay sounds like the best idea. Anybody know how I wire it to a relay ?
davey boy
« Reply #9 on: 08 March 2015, 05:19:22 pm »
I bought an automotive relay from ebay and you basically wire it through the relay to the battery and earth the relay then splice a wire into a switched circuit (i used the numberplate light) and connect this to the relay there are 3 or 4 tabs on a relay depending on the one you buy here is alink that might help http://www.mp3car.com/the-faq-emporium/117895-faq-relays-how-they-work-and-how-to-wire-it-up.html
Grayo
« Reply #10 on: 08 March 2015, 05:58:27 pm »
That's a great help. Thanks for that.
PaulSmith
« Reply #11 on: 09 March 2015, 03:17:14 pm »
That is all covered in the link to Pat's site that I posted earlier. Did you look at it?
bigralphie
« Reply #12 on: 09 March 2015, 04:12:20 pm »
No but have now , I have then Zumo 350lm and just wired to the battery but if I add anything else I think I fit a fuzebox
http://www.nippynormans.com/products/f650stf650csf650gsf650-dakar/item/fuzeblock-switchable-fuse-panel-fuz-fz1
Fazafou
« Reply #13 on: 10 March 2015, 09:37:08 am »
Tidy little unit but 70 quid is shocking. Could wire something similar for under a tenner.
davey boy
« Reply #14 on: 10 March 2015, 07:55:11 pm »
Inline fuze holder, an automotive relay a bit of wire all for under a fiver
fazer69
« Reply #15 on: 19 March 2015, 08:27:44 pm »
Fitting a Zumo 660, straight off the battery using my optimate lead, plug it in when using, job done.
davey boy
« Reply #16 on: 21 March 2015, 07:33:18 am »
Good idea I am running out of space on my battery terminals
Peasy
« Reply #17 on: 21 March 2015, 08:55:45 am »
I've got one of these to run off the battery that simply unplugs when not in use. I'll only use the nav a couple of times a year so thought this was a good quick idea.
eBay item no:400738914365
