Date: 11-05-26  Time: 16:00 pm
Author Topic: how to change a coil pack  (Read 1649 times)
One_Ball
« on: 20 January 2015, 04:01:18 pm »
Hi all, first post so please be nice  :b  is there any video's of how to change a coil pack? my 2008 s2 needs one for 1 & 4. would like to do this myself but would like video to help me out  :)
pointer2null
Re: how to change a coil pack
« Reply #1 on: 20 January 2015, 08:31:50 pm »
no vid but would be rather easy (from memory):
1) remove tank (or just remove bolt at front and lean up. watch the breather pipes don't get kinked when you put it back).
2) id coil pack - will be just below tank on bracket secured by 10mm bolts.
3) disconnect wiring
4) replace with new
If the thread about carb balancing is still working look at the pics - you can see the coils as they are moved to access carbs adjustments.
Dead Eye
« Reply #2 on: 21 January 2015, 02:44:44 pm »
I'm not sure the photos from the carb thread will apply to the S2 as it's fuel injected
Best of posting / moving this to the S2 forum so that people won't confuse it. I can't image it being any more difficult than the carb model though :)
pointer2null
« Reply #3 on: 21 January 2015, 03:07:12 pm »
s2? Ah didn't see that.
I take it back - no idea  :lol then
Ebme Geek
« Reply #4 on: 21 January 2015, 07:23:16 pm »
They are mounted in the front of the frame just behind the headstock, on the front of the battery carrier,which is infront of the air-box, which is under the fuel tank.
Its quite tight in that space, it's been a while since I had the tank off on my sons, not sure if you can get access to undo them without taking the air-box & battery carrier out, sounds daunting but is not to bad. If thats the case, you will need quite a long alen key to undo the clamps on the intake rubbers, and large combination pliers are good for the pipe clips.
The reason I was in there, was to get at the connector to the high beam switch so that I could mod it so that both of his lights were on when on low beam, that's something else you might consider while you are there, or at least putting a wire there to make it easy if you want to do it in the future  ;)
Here's a couple clips about getting as far as the battery, you can see the top coil infront of the battery
Dont bother tying the tank up, for 30 seconds work, take it off and get it out of the way and it wont get scratched  ;)
There is a big plastic clip that makes sure the fuel pipe does not come off, then the fitting self seals when you unplug it, just have a couple of rags around for the odd dribble out of the pipe.
Hope that goes towards helping.
