Date: 08-05-26  Time: 08:27 am
Author Topic: Cheapest cartridge emulators, Debrix no more?  (Read 9220 times)
Nebuchernezzer
« on: 18 January 2015, 11:56:10 pm »
What are the options for cartridge emulators for the old FZS these days?
We put debrix emulators in the track bike but it appears they are no more? Can't get onto their website anymore so i'm assuming they are defunct.
Is gold valves the only other option apart from that?
Re: Cheapest cartridge emulators, Debrix no more?
« Reply #1 on: 19 January 2015, 05:32:11 am »
Need to contact them to see if they have a pair.
http://www.fazerspares.com/catalogue/126-1_suspension.htm
kebab19
« Reply #2 on: 19 January 2015, 10:14:49 am »
Darrsi,
These are not standard fork parts, but an aftermarket mod on forks that I publicised last year:
http://foc-u.co.uk/index.php?topic=8366.0
http://foc-u.co.uk/index.php/topic,9279.0.html
So Fazer spares won't ever have them in stock.
Nebuchernezzer:
These babies appear to be the droids you're looking for - ebay item # 161561746981
But maybe only 1 set left? Get in quick!
Not sure what's happened to the Debrix site, hopefully it's only down temporarily, otherwise Racetech or YSS emulators may be your only (expensive) options.
EDIT: Another Stateside ebay seller here, but more expensive - # 191170530552
Nebuchernezzer
« Reply #3 on: 19 January 2015, 09:05:18 pm »
Awesome thanks!
The Debrix site has been down since i got my bike around 5 months ago :(, so sadly it seems to be an ongoing thing....
Postage is a killer from the US isn't it! But still cheaper than racetech....
kebab19
« Reply #4 on: 19 January 2015, 10:10:25 pm »
Yes, the postage was always a killer, hence my Group buy of emulators to save $$$ back in 2013.
You could also try putting a Wanted post on the SV650.org forum as the Suzuki bods seem a lot more keen on the emus, someone might still have a pair for sale.
Nebuchernezzer
« Reply #5 on: 19 January 2015, 11:09:20 pm »
I'm in Oz so i'm probably stuffed either way!
But speaking of SV650 perhaps the SV650 people will be able to tell me the dimensions of standard  SV650 fork springs.  Saw some on gumtree and they are straight rate and from 41mm tubes....might be good in the fazer, but might also be not much of an upgrade at 0.7kg spring rate...$30 though so not bad.
kebab19
« Reply #6 on: 20 January 2015, 08:43:39 am »
Aftermarket SV650 springs would be an option, but as those bikes are some 20kg lighter than the FZS they'd need to be a fairly high spring rate.
Aftermarket Bandit 600 ones (if available there) could be a better good choice as they're heavy old buses.
For both my emu conversions I used standard springs from a 94-97 Honda VFR750 and then an early VFR800; although technically dual rate, from memory they averaged around 0.85kg which suited me fine.
savvy
« Reply #7 on: 20 January 2015, 07:59:04 pm »
have you thought about CBR springs? I used them and Thundercat fork tops adjustable but need a shorter spacer. See at the end of Kebab's topic as to how I did mine.
Thanks again Kebab!!
http://foc-u.co.uk/index.php/topic,9279.msg131635.html#msg131635
Nebuchernezzer
« Reply #8 on: 20 January 2015, 09:14:43 pm »
It seems for my body weight i'd want about 0.8kg or a bit more roughly?
I'm 68 kg without gear on.
I have just bought a 2013 R6 rear shock as well.  So get that with say a 650lb spring and i should be set.
Oh yeah my mate sent me this link so i ordered my valves from here.
http://www.motoparthub.com/24_0361_VTwin_41mm_Fork_Damper_Valve
kebab19
« Reply #9 on: 21 January 2015, 01:40:37 pm »
According to this spring rate chart:
http://www.mad-ducati.com/Technical/racetech/springchartstreet.gif
You're about halfway between 0.80 and 0.85kg ... suppose it depends how comfortable you want things to be!  You should indeed try 0.8 kg first as its kinda hard to stick bits of spring back on again :rollin
Znd93rus
« Reply #10 on: 21 January 2015, 02:12:31 pm »
Sorry for stupid question, but all links for emulators are for H.D. ones not for Fazer. is it correct?
kebab19
« Reply #11 on: 21 January 2015, 03:24:33 pm »
Not a stupid question at all.
A few years ago, some SV650 owners noticed these HD emulators suited 41mm diameter forks (and also noticed how cheap they were).
They found that they were a straight for 1st Gen SV650 forks.
In 2013 I discovered they were also perfect fit for Fazer FZS600 forks.
The 'debate' about whether the Emulator's preload spring is too firm (to accommodate the extra weight of Harley Davidsons) is IMO a non-issue, as backing it's preload off makes it ideal for much lighter bikes such as Fazers
Znd93rus
« Reply #12 on: 21 January 2015, 04:54:41 pm »
Kebab19, that means that this emulators are great straight mod for Fazer? Have you or any forumriders tested it?
I am thinking about suspention tuning. Maybe USD maybe EMU... need more information. But start from EMU looks less expensive and need less time to install.
kebab19
« Reply #13 on: 21 January 2015, 10:27:05 pm »
They are the best modification you can do to the standard forks (if fitted alongside replacement springs).  Obviously replacement cartridge forks swapped from other bikes would be even better.
Yes, I first ran Racetech Emus in the forks back in 2008:
http://foc-u.co.uk/index.php/topic,71.0.html
And again with cheaper Debrix Emus when I bought my second Fazer 600:
http://foc-u.co.uk/index.php/topic,8366.0.html
And talked a few other forum members into a Group Buy:
Znd93rus
« Reply #14 on: 22 January 2015, 07:15:52 am »
Kebab19, thank you for info. I found local springs manufactor with good prices and now plan to source for R6 shock and emu.
Kebab, do you have any info about suitable for FZS600 catridge forks? And I can't find (I know and I saw your posts about it) which R6 shock good for and what parts I need for setup. Please give me link.
