Date: 01-05-26  Time: 17:57 pm
Author Topic: heated grips fazer 1000  (Read 4325 times)
gerkin
« on: 17 January 2015, 06:26:25 pm »
where do you connect to the loom ?
fitting some to a mates 1000 fazer next week
cheers gaz
bobdog
Re: heated grips fazer 1000
« Reply #1 on: 17 January 2015, 07:49:31 pm »
if you get the latest oxford ones, the £70 type you can connect straight to the battery as they turn off if you forget :)
nsr500v4
« Reply #2 on: 17 January 2015, 10:22:51 pm »
The Datatool grips go straight to battery too, fancy electronics inside to stop them working unless bike ignition is on too.
Red fazer
« Reply #3 on: 18 January 2015, 11:26:30 am »
I wired mine through a relay and connected it to back brake light switch feed so they come on and off with ignition
PJ
« Reply #4 on: 18 January 2015, 11:43:31 am »
Thanks Gerk, I've got the R&G grips...
Arunmax
« Reply #5 on: 20 January 2015, 01:41:12 pm »
b1k3rdude
« Reply #6 on: 22 January 2015, 02:25:24 pm »
The "Dr Bike" heated grips are made by the same place that makes the oxford ones, and the version 1.0 kit (linked) comes with the analogue controller (doesn't auto-on, with ignition) and has an easy to use analogue controller (unlike the v2.0 and Oxford grips). And lastly they can be had from £30-40 brand new.
I have a set on my Bandit 1200 along with a par of modded(I trimmed the end sleeve down a bit and used the bar-end bolt to secure them) Tech7 handlebar muffs.
