Date: 01-05-26  Time: 11:17 am
Author Topic: Shite quality disc bolts  (Read 4856 times)
Rexr
« on: 12 January 2015, 12:42:33 pm »
Well there's one thing u can rely on with Yamaha and that's their shite quality standard disc bolts, I think their made of fecking cheese and why use different ones on the back (in fact beefier ones on the back) where's the fecking sense, I can see the drills coming out this week, if the heat and torx bits don't work........rant over for now lol ggggrrrrrr.........:(
slimwilly
Re: Shite quality disc bolts
« Reply #1 on: 12 January 2015, 07:10:32 pm »
So is it worth attempting to take mine out,57 plate FZ1s , to refit then and know they will move ????
JoeRock
« Reply #2 on: 12 January 2015, 07:52:32 pm »
Yes. But don't try it without an impact bolt. Probably worth replacing them with titanium whilst you're at it - about £35 a full set off eBay!
slimwilly
« Reply #3 on: 12 January 2015, 08:10:47 pm »
OK, there's a challenge, oh and any reccomendations on refitting, i.e ,,dry..with grease,,threadlock , paint ?
JoeRock
« Reply #4 on: 12 January 2015, 09:18:09 pm »
If you do get titanium, i'd definitely recommend some copper grease, otherwise they will dry weld themselves to your wheel, and you'll never get the bastards out. Just a little bit, and make sure if you torque them up you drop about 30% off the torque value to account for the grease!
Then just check them every now and again - I've never had any come loose due to the above, but better late than sorry!
Rexr
« Reply #5 on: 13 January 2015, 12:07:44 am »
The rears came out nae bother and I've got a full set of titanium to replace them......I had the same issues with my xjr.......
Tmation
« Reply #6 on: 13 January 2015, 04:06:16 am »
You should use a semi permanent thread lock when fitting disc bolts, not copper grease. If you buy new Yamaha ones you will see some blue stuff in the threads, I can't remember the loctite equivalent off the top of my head.
JoeRock
« Reply #7 on: 13 January 2015, 12:47:46 pm »
And that's the stuff that locks down hard over time and makes them a right bugger to get out!
fazer390
« Reply #8 on: 13 January 2015, 01:40:55 pm »
I've spent the last 2 weekends stripping, polishing and painting my wheels on my gen 1. Surprisingly I didn't get any real problems removing the disc bolts; I was obviously lucky...
I have replaced them however with Stainless bolts from Ebay knowing I'd get issues with the old cheese bolts in the future!
Getting new tyres fitted this afternoon and I can't wait to get the wheels back on the bike later... :-)
Rexr
« Reply #9 on: 13 January 2015, 03:04:45 pm »
Well with a bit of heat they came out very easy (bang in a torx bit take it back out and heat the bolt up for about 30 seconds and insert the torx bit and undo.... :) )
Tmation
« Reply #10 on: 13 January 2015, 06:40:34 pm »
The front and rears come out easy with a bit of heat and an impact wrench, you need that to break/soften the loctite.
Appliance of science and nearly 40 years of doing stuff like that  :) [size=78%] [/size]
