Date: 22-03-26  Time: 23:17 pm
Author Topic: Removing gear indicator, part required  (Read 2463 times)
Pal
« on: 03 January 2015, 04:25:58 pm »
Hi
I'm removing an old broken LED gear indicator and I want to replace to gear sensor plate from the kit with the standard one.
Does anyone have one or know the part number I need?
Pal
Re: Removing gear indicator, part required
« Reply #2 on: 03 January 2015, 04:48:45 pm »
I had a look on there but I can seem to locate the sensor.
I can find the shift drum that it goes on the end of, but no sensor, the electrical page is just about ignition stuff.
Could you point me to the sensor?
« Reply #3 on: 03 January 2015, 07:13:13 pm »
Gear indicators are an add on, they're not standard kit.
Pal
« Reply #4 on: 03 January 2015, 08:19:53 pm »
I realise the gear position sensor is not an original part, what I'm after is the standard neutral position sensor plate that has been replaced on my bike when the gear indicator was fitted. Has anyone got one spare or can supply the part number please?
« Reply #5 on: 04 January 2015, 10:55:49 am »
Sorry fella, i'm not entirely sure what part you're on about?
« Reply #6 on: 04 January 2015, 10:13:45 pm »
These are the parts you need
Neutral Switch part number is 1AE−82540−00 and maybe an oil seal part number 93210−29196
If the wire to the switch was cut to fit the led indicator you may also need the cable 5RT−82541−00
These parts should be available from a breaker
Pal
« Reply #7 on: 08 January 2015, 07:38:52 pm »
Cheers mate that's exactly the information I needed
The original wire is still screwed to the replacement switch, in addition to the cable for the gear indicator, so just the switch and seal will do me.
Thanks again
