Date: 12-05-26  Time: 09:35 am
Author Topic: Swing arm  (Read 3615 times)
emjaydee
Swing arm
« on: 17 November 2014, 09:01:46 pm »
Hi,  Does anybody know what Fazer this swing arm came from?  Only asking because the front chain guard mount is missing or do you think it's snapped off.
Thanks
BBROWN1664
Re: Swing arm
« Reply #1 on: 18 November 2014, 03:27:00 pm »
It does look like an FZS600 swing arm.
kebab19
Re: Swing arm
« Reply #2 on: 18 November 2014, 05:42:18 pm »
Agreed, the ugly wheel spindle slot indicates it's off one of ours
Stored at the bottom of a pond?
emjaydee
Re: Swing arm
« Reply #3 on: 18 November 2014, 06:41:20 pm »
Made the mistake in buying this a couple of days ago but just realised a chain mount is missing :( .
bozboz
Re: Swing arm
« Reply #4 on: 18 November 2014, 11:34:47 pm »
I've got one as dirty but all mounts attached if you want it? Near Sevenoaks kent
bozboz
Re: Swing arm
« Reply #5 on: 19 November 2014, 12:00:09 am »
emjaydee
Re: Swing arm
« Reply #6 on: 19 November 2014, 09:35:00 am »
Many thanks for the offer but you are a bit too away.
limax2
Re: Swing arm
« Reply #7 on: 19 November 2014, 10:35:15 am »
The dirty swinging arm in the photo looks like it is from a 1998-2001 Fazer 600, but with the chain guard front mounting missing. If broken you should be able to see the remains of it where it was welded on. If cut off and cleaned up in the past you may not see evidence due to the corrosion etc.
For your information the hole in the rear bracket on the 1998-2001 models is 160mm from the back of the swinging arm and 20mm up from the top face.
On the 2002-2003 (Foxeye) models the hole in rear bracket is 120mm from the back and 50mm high.
Hence chain guards or huggers are not directly interchangeable.
emjaydee
Re: Swing arm
« Reply #8 on: 19 November 2014, 07:42:55 pm »
Thanks Limax2 for the info.
I was going to clean this up and paint it satin black to see what it looked like on the bike, instead of using me existing swing arm.  I can still do it but without a chain guard.
papercutout
Re: Swing arm
« Reply #9 on: 19 November 2014, 07:48:37 pm »
I'd just do it too. Might as well, huh? Easier with a hugger, just miss off the front mount, and make sure it's secure on the other side. (and the answer - it looks MUCH better satin black, mine is)
