Date: 12-05-26  Time: 03:37 am
Author Topic: Misfires when wet  (Read 2326 times)
emjaydee
Misfires when wet
« on: 09 November 2014, 10:32:01 pm »
Hi,
        On Friday afternoon while it was raining I started my 25 minute journey home, it started fine and ran fine for 15 minutes then my bike started misfiring.  It seemed to only misfire at low revs.
What would likely cause my bike to misfire when it's wet/raining?
Water on the HT leads? Water in the tank? Water in the carb?
Thanks
His Dudeness
Re: Misfires when wet
« Reply #1 on: 10 November 2014, 08:59:39 am »
It's water getting in under the spark plug caps. The rubber boots are probably past their best. Take the caps off one at a time and dry the insides. Also clear out the drain holes in the cylinder head.
Deefer666
« Reply #2 on: 10 November 2014, 09:40:07 am »
Or the ht leads starting to break down.
stevierst
« Reply #3 on: 10 November 2014, 09:58:22 am »
As far as I remember there's a big rubber flap that sort of shrouds the spark plugs. Is that in the right place? As that's what its designed to prevent,
emjaydee
« Reply #4 on: 10 November 2014, 10:26:35 am »
Thanks for the advice, guys.  I well check all these when I get home tonight.  BTW the bike started and ran great coming to work this morning.
Paul
« Reply #5 on: 13 November 2014, 01:37:14 pm »
Check out the water drain holes on the sides of the cylinder head.
Mine cut in wet weather once because one of them was blocked up.
