Date: 15-05-26  Time: 13:35 pm
Author Topic: fz1s gen 2 suspension play  (Read 2307 times)
bikerally
« on: 07 November 2014, 12:38:34 pm »
hi guys,  i have just replaced the suspension bearings on the linkage arm & the bearing under the swing arm. also replaced the nuts & bolts and linkage plates while i was at it.  I notice if u lean over the seat and grab the swing arm it lifts slightly. is this normal to have this play before the shock works ?  cheers ally.
devilsyam
Re: fz1s gen 2 suspension play
« Reply #1 on: 07 November 2014, 01:04:44 pm »
Gen 1 has it never looked for it on a gen2
stevierst
« Reply #2 on: 07 November 2014, 07:07:36 pm »
Yep, perfectly normal.
It shocked the hell out me when I first did it. There should be a couple of mm of play at the wheel spindle, don't know what the high end tolerances are though.
bikerally
« Reply #3 on: 08 November 2014, 12:12:13 am »
thanks for that. before i went to work i phoned yamaha uk motorcycle technical dept & they said that its normal to have play as with the barings collars and bolts going through also.
solorider
« Reply #4 on: 08 November 2014, 03:23:07 pm »
My gen 1 doesn't have any play but I had a FJ1200 that did even with new bearings, the lower shock bearing is of a different design to the gen 1 so that may explain things.
