Date: 07-05-26  Time: 03:14 am
Author Topic: fix for this?  (Read 6511 times)
tweetytek
fix for this?
« on: 23 October 2014, 06:35:48 pm »
The l/h  leveling adjuster has cracked all around the screw. so the headlight is rocking back and forth freely. anyone had this and found a fix other than buying a entire new headlight assembly. I'd take a pic but my phone camera aint working - no other camera - but suffice to say there is a 360 degree hole now around the screw. Thinking of putting a black rubber washer on the outside then push the adjuster screw through into the inner assembly, so if I unscrew all the way does the adjuster come out? I didn't want to try in case it's a bugger to get back in?
Re: fix for this?
« Reply #1 on: 23 October 2014, 06:51:51 pm »
It can be welded fairly easily with a soldering iron.
tweetytek
Re: fix for this?
« Reply #2 on: 23 October 2014, 06:54:16 pm »
thanks for the insight. sounds simple but how? I do not own a soldering iron so what type would I need and what is the procedure? would it not just melt a thick gouge around the screw?
EDIT: http://www.ehow.co.uk/how_8001797_weld-plastic-soldering-iron.html
like this?
Doddsie
Re: fix for this?
« Reply #3 on: 23 October 2014, 09:15:08 pm »
Super glue and bicarbonate of soda. Its not pretty but it works.
tweetytek
Re: fix for this?
« Reply #4 on: 23 October 2014, 09:17:31 pm »
Sorted with the. Soldering iron. Not pretty but Lewis rain or and I'll tidy up at wkend. Ta
midden
Re: fix for this?
« Reply #5 on: 24 October 2014, 12:22:41 am »
what does the bicarb do?
Doddsie
Re: fix for this?
« Reply #6 on: 24 October 2014, 01:43:08 am »
If you glue 2 surfaces together, then go over the join with a bead of super glue, then sprinkle with Bicarbonate of soda, then glue, then again with bicarbonate of soda etc. Do this 5 or 6 times and the bicarbonate of soda forms a very hard, plastic like crust, much stronger than just super glue on its own.
Doddsie
Re: fix for this?
« Reply #7 on: 24 October 2014, 02:03:44 am »
Not the best quality but it kinda gives you the idea. Just remember to use bicarbonate of soda ( which the Yanks call baking soda ) and not baking powder.
stevierst
Re: fix for this?
« Reply #8 on: 24 October 2014, 05:53:41 am »
That's impressive! It's almost like quick drying epoxy resin. I'm off to get some baking soda
His Dudeness
Re: fix for this?
« Reply #9 on: 24 October 2014, 09:00:54 am »
q bond is the business. you fill the gap with the filler plastic powder and then add the glue. easy! works great at fixing cracks, you just open out the crack, build it up with the powder and glue, then sand it flat. it looks like original plastic after you've sanded it. you can even create a new piece of plastic with it if something has snapped off like a mounting tab or you could fill a hole and tap it if you've stripped plastic threads. it's excellent stuff!
Re: fix for this?
« Reply #10 on: 24 October 2014, 10:15:13 am »
What language are you speaking there???  :look
tweetytek
Re: fix for this?
« Reply #11 on: 24 October 2014, 02:16:31 pm »
Typo on this fukin stupid phone
Anyway, not sorted. Came down this morning gently adjusted the leveler and the home just opened up. Fukin really pissing me off. Superglue n bicarb didn't work either. Grrrr.
This qbond stuff...how does one patch a hole?
His Dudeness
Re: fix for this?
« Reply #12 on: 24 October 2014, 02:19:28 pm »
Can you get a picture of the damage?
tweetytek
Re: fix for this?
« Reply #13 on: 24 October 2014, 02:22:58 pm »
wish I could. No working camera. Will get away over to take a pic but basically it's dead simple, the area  I circled blue... ain't there!
His Dudeness
Re: fix for this?
« Reply #14 on: 24 October 2014, 02:37:26 pm »
The q bond stuff will rebuild broken plastic. I can't tell you for sure if it'll work without seeing the damage but there's videos on youtube showing examples of what can be done with it
Q Bond Πανίσχυρος Συγκολλητής- 11 Φτερό Μηχανής
tweetytek
Re: fix for this?
« Reply #15 on: 24 October 2014, 02:51:03 pm »
Ok dude. Cheers.
Sussed a way. I shall use some  auto gauze sheet,as used in body filler, craft a 3x3 cm square patch and apply Superglue and bicarb,  using tweezers quickly apply over the hole pressing around the edges and leave to set. Then sand off,paint and drill the hole. Sounds like this will work
His Dudeness
Re: fix for this?
« Reply #16 on: 24 October 2014, 02:53:14 pm »
It could well be mad enough to work.
mobile mouse
Re: fix for this?
« Reply #17 on: 25 October 2014, 11:17:50 am »
Hi,
When you use the soldering iron to plastic weld you need to use cut pieces of metal from a paper clip. they are pushed into both sides across the crack to act like a stitch it reinforces the join as well you can youtube it to see how it's done
tweetytek
Re: fix for this?
« Reply #18 on: 25 October 2014, 11:58:53 am »
That takes me back to childhood.. Well teenage years. What of course annoyed all the kids,was when all the bullets rained down,cars overturned, fuel cells blown up, buildings peppered with grenades...and yet no focer died  :2guns :lurk  :D
Fazafou
Re: fix for this?
« Reply #19 on: 25 October 2014, 01:57:31 pm »
Best plastic welding I've seen is Delboys Garage on YouTube.
He uses paper clips as said above, but uses cable tie is the 'solder' to fill and glue the gap.
Works a treat and remains flexible which a lot of other fixes like superglue/bicarbonate doesn't.
Doddsie
Re: fix for this?
« Reply #20 on: 25 October 2014, 07:13:45 pm »
Ah, but thats not as good if you dont want it to be flexible!!   ;)
tweetytek
Re: fix for this?
« Reply #21 on: 30 October 2014, 09:48:09 pm »
All done the mad way as above
