Date: 07-05-26  Time: 07:56 am
Author Topic: Finding Neutral  (Read 2146 times)
coolhandluke
Finding Neutral
« on: 19 October 2014, 02:20:26 pm »
Hi Guys / Gals, during a chain and sprocket change, ive taken the front sprocket cover off get at the sprocket and in doing so had to take off the gear linkage lever. i tried to score it so finding the correct position when reassembling it wouldnt be an issue but i didnt do it very well. tried to find the correct position and its no longer in neutral and i cant find neutral when trying to come through the gears. has anybody had this before and what did you do!!
thanks in Advance!
coolhandluke
Re: Finding Neutral
« Reply #1 on: 19 October 2014, 02:41:41 pm »
Ive sorted it. the sprocket had turned slightly so i just put it back to its original position and it poped back into neutral. hope this will help any other numpties like me :)
Deefer666
Re: Finding Neutral
« Reply #2 on: 19 October 2014, 04:56:56 pm »
if you clean the crud off, there is a dot punched into the end of the gear shaft. Use that to align the selector mechanism.
