Date: 08-05-26  Time: 08:27 am
Author Topic: Lowering FZ6 Rear Shock  (Read 10606 times)
Grahamm
  • Global Moderator
« on: 10 October 2014, 09:24:28 pm »
I'm thinking of getting a lowering connector for the rear shock on my FZ6 (see www.ebay.co.uk/itm/Yamaha-FZ6-Fazer-S2-RJ14-2009-MFW-Lowering-Kit-Drop-35mm-/130768980805 )
What I'm wondering is whether I'd need to drop the yokes by a similar amount to keep the handling the same?
JoeRock
Re: Lowering FZ6 Rear Shock
« Reply #1 on: 10 October 2014, 10:43:36 pm »
Don't think that'll work on yours mate - From what I remember the first Gen FZ6 had a direct shock from frame to swingarm, was only the second gen that had linkages?
Why you wanting it anyway?
Grahamm
  • Global Moderator
« Reply #2 on: 11 October 2014, 02:05:36 am »
Yes, this shortens the shock (it's not dog bones).
Quote
Because I've got short legs and the bike is too high even with a cut-down seat :(
« Reply #3 on: 12 October 2014, 06:38:52 pm »
Try raising the forks through the yolks first by 10mm. Be aware that dropping front and rear will reduce your cornering clearance.
Other option is to try lowering the seat by removing the foam and adding gel in its place.
Met a girl in southern France a few years ago with a foxeye fazer and that was what she told me she did.
Grahamm
  • Global Moderator
« Reply #4 on: 13 October 2014, 06:41:33 pm »
I'm not into scraping knees, so I won't worry about that too much.
Although I'm just wondering if the forks have been raised through the yokes already as I recall trying to get it lowered a bit when I bought it (that was 7 years ago). As far as I can measure it, it appears to be about 740mm from the top of the yoke to the centre of the front wheel. Does anyone know if this is the standard measurement?
Quote
I've already had the seat cut down, but it's not enough :(
Grahamm
  • Global Moderator
« Reply #5 on: 19 October 2014, 01:10:33 pm »
Bump!
If anyone has an FZ6 (04-06) and could check this measurement I'd be very grateful...
High Peak Fazer
« Reply #6 on: 19 October 2014, 05:28:49 pm »
Hi mate the top of the fork leg should be flush with the top of the clamp with only the thickness of the screw in cap above the clamp Hope this helps
Grahamm
  • Global Moderator
« Reply #7 on: 20 October 2014, 12:41:46 am »
Thanks for the reply, but I'm not sure exactly what you mean.
I've attached a pic of the top of the forks, there is a "step" at the top of the yokes, is this how they look as standard?
Grahamm
  • Global Moderator
« Reply #8 on: 24 October 2014, 01:10:43 am »
Sorry to bump this again, but I'd appreciate it if someone could confirm if this is how the top of the forks look on a stock bike before I start playing around with things...
pringle_addict
« Reply #9 on: 11 December 2014, 01:31:02 pm »
Hopefully attached, are a couple of shots of mine at the moment. Not taken specifically to show the forks, but you can see fork tops and fronts in these shots. The bike is standard, as I had it from nearly new (ex-demo).
Hope this helps.
« Reply #10 on: 11 December 2014, 02:47:21 pm »
With the fork cap bolt off, the top of the fork leg tube (stanchion) should be flush the the top of the Yolk.
Grahamm
  • Global Moderator
« Reply #11 on: 12 December 2014, 12:37:02 am »
Hmm, ok that looks like mine are as original, not been lowered.
Thanks.
