Date: 07-05-26  Time: 07:56 am
Author Topic: Carbtunes in yorkshire  (Read 3206 times)
ajmes1
« on: 05 October 2014, 11:40:52 am »
Would anyone near selby, north yorks, have a carbtune or similar that I could borrow along with a hand to balance the carbs?
Getting an annoying vibration through the pegs between 6-7.5k revs in any gear and thought it's probably worth checking the balance.
Re: Carbtunes in yorkshire
« Reply #1 on: 05 October 2014, 12:46:52 pm »
Double check engine mounting bolts are torqued correctly.
Also have a look at how the centre stand rests on the end can link pipe as well, it may need a little adjustment as that could send vibes towards your feet, and obviously check that your exhaust bolts are all as they should be.
Fazer Forever
« Reply #2 on: 05 October 2014, 05:11:33 pm »
I've got some you can borrow, you know where I live! I'm busy the next couple of weekends though, then on holiday.
Could give you a hand after that though if you need it.
tweetytek
« Reply #3 on: 05 October 2014, 10:15:03 pm »
carbtune is for idle , the throttle links are adjusted to balance the carbs. At wider throttle the balancing insnt going to do that much, but it will improve like MPG I suppose.
Check your mountings and fasteners and check the peg bolts are tight , probably need to take them off the bike at the bracket - only two bolts to remove. Check tank bolt near yolk and tank support rubbers
ajmes1
« Reply #4 on: 07 October 2014, 10:02:30 pm »
Brill thanks for all the advice,
And fazer forever, that would be great thanks, I'll drop you a pm in a few weeks if that suits. I can repay in beer etc. if required!
Fazer Forever
« Reply #5 on: 08 October 2014, 12:46:15 pm »
No probs, just give me a shout when you're ready.
ste131
« Reply #6 on: 09 October 2014, 09:44:21 pm »
Any hassles with your bike then just call round. Im in Pudsey and have balancing kit.
