Date: 07-05-26  Time: 13:02 pm
Author Topic: Odd question: Seeking exact measurements/template for speedo surround  (Read 8970 times)
helloindustries
Update: I've made one, get it over here.
I've had no luck with my google-fu, and the last product i had from ebay wasn't cut to the correct size, and the seller was an arse.
So: I'm trying to find the actual measurements, unless of course; I can remove the gold surround to apply vinyl then cut to fit?
Re: Odd question: Seeking exact measurements/template for speedo surround
« Reply #1 on: 04 October 2014, 12:32:57 pm »
Yep me too, I fancy a brushed stainless steel one to (not vinyl) pop over the gold one would look much better on my black and silver bike
helloindustries
« Reply #2 on: 04 October 2014, 12:41:47 pm »
Well, whichever way I get this done; i'll be sure to post up a template.
« Reply #3 on: 04 October 2014, 01:16:13 pm »
buy’ ngop
helloindustries
tweetytek
« Reply #5 on: 04 October 2014, 02:05:41 pm »
what is it that you are trying to do - I dont understand. do you mean remove the plastic fascia  that sits around all the dials - it pulls off??
helloindustries
« Reply #6 on: 04 October 2014, 02:28:23 pm »
See the brass/gold surround which sits around the rev and fuel guage?
My aim is to cover that with vinyl as I think it could look better.
tweetytek
« Reply #7 on: 04 October 2014, 02:37:58 pm »
Oh I see what you mean.
I did this but not with my Fazer, another bike. I dont have pics but can tell you what I did..
I used a piece of sticky back carbon fibre square larger than the square (shape) of the area being covered. So in this case enough to cove the gold fascia.
Make sure its a square shape. Place over and make a mark with liquid paper or dab of white paint, where you can feel the clocks. Take away the card then make a hole where the paint dabs are. Make a cut starting from the hole , outward, about 2 cm, into an "X" shape. Place the card back over the clocks and push the card down and the "X" over the clock. May need to increase the "X" size - trial and error, but do it in SMALL STEPS, like 1/2 cm at a time. push card down and around the base of a dial and using a craft knife cut around the base of the dial to make a neat circular cut.Take off the card and remove the backing paper then starting at the top put the card over and fit into place.
« Reply #8 on: 04 October 2014, 03:34:37 pm »
buy’ ngop
What?
Its Klingon you idiot !!!! ---------- took me feckin ages to find it. It means "good work" or good, actual transaction is "plates are full" which is a sign of things good and well being in klingon.
« Reply #9 on: 04 October 2014, 03:35:40 pm »
I fancy a lazer cut proper stainless steel one
tweetytek
« Reply #10 on: 04 October 2014, 04:11:53 pm »
use a pair of sharp scissors !
helloindustries
« Reply #11 on: 04 October 2014, 05:26:24 pm »
buy’ ngop
What?
jIyaj
« Reply #12 on: 04 October 2014, 05:45:15 pm »
buy’ ngop
What?
jIyaj
At Last !
helloindustries
« Reply #13 on: 04 October 2014, 07:08:38 pm »
buy’ ngop
What?
jIyaj
At Last !
Helloindustries; His eyes open.
« Reply #14 on: 04 October 2014, 07:12:32 pm »
Can we stop now
helloindustries
helloindustries
« Reply #16 on: 04 October 2014, 07:32:23 pm »
aaaand back on topic...
I like this idea, thanks!
I'll give it a go as soon as i'm able.
I'll try it with paper, so that:
1. I don't waste vinyl
2. I can make a template
« Reply #17 on: 04 October 2014, 07:35:34 pm »
how wrong was the ebay one and could you use that as a starting point. Where was it wrong
helloindustries
« Reply #18 on: 04 October 2014, 07:37:48 pm »
It wasn't wide enough.
The fuel guage part was perfect, but the further left you went, the worse it got.
I'm confident that i can make a near-exact template, though.
tweetytek
« Reply #19 on: 04 October 2014, 09:20:42 pm »
practice with thin card - like the big side of a cereal box - thats what I did. Although the card may not be easy to cut around the base of the dials , bear this in mind. When done correctly, using quality plastic backing card, you wont be able to tell the difference until you touch the plastic cover versus a laser cut alloy template - but then again the alloy is like x10 more expensive  ;)
helloindustries
« Reply #20 on: 13 October 2014, 07:06:12 pm »
I made and tested my template today with basic paper. Perfect fit first time.
See here.
tweetytek
« Reply #21 on: 13 October 2014, 07:36:34 pm »
 :thumbup
Just as I did and my recommended method . Easy! Well done
helloindustries
« Reply #22 on: 13 October 2014, 07:41:01 pm »
What i actually did was:
  • Find image of a pre-made version (likely wrong)
  • Measured parts on bike
  • Adjusted template to match
tweetytek
« Reply #23 on: 13 October 2014, 09:28:46 pm »
Not what I recommended then. But if it works ..
« Reply #24 on: 15 October 2014, 02:12:34 pm »
I have a set which I would swap for your creation when you have them completed. :)
