Date: 11-03-26  Time: 16:14 pm
Author Topic: Fazer fork conversion  (Read 4428 times)
Pip
« on: 23 September 2014, 08:39:22 pm »
Evening All
Am trying to fit upside down forks (4xv 5jj) to my 02 Fazer 1000. Am using a R1 bottom yoke and a Fazer Gen 2 top yoke.
Yokes have been professionally altered to fit.
Am not confident about  this. Has anyone else tried this combination?  Any probs I should know about?
Any advice appreciated.
Re: Fazer fork conversion
« Reply #1 on: 23 September 2014, 09:23:35 pm »
Take a look here if you haven't already seen this thread:
http://fazer1000.yuku.com/topic/3408/R1-Fork-Conversion-Guide
My experience is with the R1 top and bottom yokes, so I don't know for sure about the finer points of using the Gen 2 top yoke.  However, it's a common option and works well, so probably easier than what I did. :)
If you have had the Gen 1 steering stem installed in the R1 lower yoke, and spacers provided as part of the professional alteration, then all you have to do is alter the steering lock stops (possibly not necessary with the Gen 2 top yoke), sort out the ignition switch swap and fit the R1 fork legs to the yokes.
You may need to get different brake lines if the originals aren't the right length.
Like any mod of this kind, a certain degree of 'suck it and see' comes into the process but you're following a proven path, so no major pitfalls await you.
sadlonelygit
« Reply #2 on: 23 September 2014, 09:25:18 pm »
you need to make sure the fork offset is the same for both yokes otherwise you'll have problems.
devilsyam
« Reply #3 on: 24 September 2014, 10:20:30 am »
Gen2 upper won't work with older r1 bottom you need fz1 bottom or 8 or 08+ r1 but these you can't pin as in mikes method you need a sleeve welding in
Pip
« Reply #4 on: 24 September 2014, 05:44:43 pm »
Thanks to all for the info. It's suggested that the gen 2 yokes won't work.  Any details as to why?
sadlonelygit
« Reply #5 on: 24 September 2014, 06:25:47 pm »
i'll keep it simple for you
R1/FZ1 yokes won't fit straight in, the steering stems are different.
you have to remove the stem from the R1/FZ1 yokes and fit a fazer stem, which has a maginally smaller od than the R1 stem (don't know about FZ1) so has to be fixed in place by either a rollpin or making up a sleeve to provide an interferance fit.
it is not a simple bolt on job!
HTH
devilsyam
« Reply #6 on: 24 September 2014, 07:53:44 pm »
both are right but wrong ill try to explain
gen1 stem in older lower r1 yoke with pin method but cant use gen 2 upper
gen 1 stem into fz1 or late r1 bottom will go but pin method wont work as sad said the stem is smaller
this require a bit of machine shop work
stem needs 2mm machining off and a 3mm top hat bush making this is then welded onto the fazer stem
then remachining down to bearing size
sounds epic but not really my local engineering shop have done 7 of these now cost is £160
but the advantage is no cutting of the lock stops and you can use gen2 top yoke which makes the whole conversion look more factory
