Date: 08-05-26  Time: 15:00 pm
Author Topic: Swingarm failure - torque arm mounting point  (Read 27385 times)
Re: Swingarm failure - torque arm mounting point
« Reply #50 on: 26 September 2014, 08:40:47 pm »
See my comment http://foc-u.co.uk/index.php/topic,14772.msg168096.html#msg168096
I slacken the bolts and torque them to 23Nm out of habit, however 23 Nm is not tight enough to lock the torque arm solid and it will move without damaging the arm, or pivots, but as I said previously:
Everybody knows the rule "if in doubt swing out of it"  :lol :lol :lol
There have been many occasions when adjusting the chains for others I have had difficulty in opening the bolts on the torque arm because of the "if in doubt swing out of it"
For the above reason I tell people to slacken off the pivot bolts and tighten them when finished adjusting the chain, and not to over tighten them afterwards, this prevents the "if in doubt swing out of it" causing problems. :eek
Paulfzs
midden
« Reply #52 on: 17 October 2014, 02:42:02 am »
I would actually question the need to tighten the torque arm to the extent it wouldn't adjust with the caliper bracket rotation when moving the wheel back or forward.  Afterall as already mentioned the bar is only to stop the caliper bracket from spinning. Obviously not too loose, just enough that with a bit of effort it can be lifted and lowered.
agreed! who said to tighten it like that anyway? that sounds - to me - what caused the problem in the first place
Because everybody knows the rule "if in doubt swing out of it"  :lol :lol :lol
How many do you know who do their own maintenance actually own a Torque Wrench?  :eek :eek :eek
I have one  :b
midden
« Reply #53 on: 17 October 2014, 02:54:20 am »
Yes but you are quoting a yamaha SHOP manual . it assumes a working level competence within the shop bay at the DEALER garage. All staff undergo general yamaha centric DEALER/franchise training and this sort of document is merely a guide for THE SPECIFIC BIKE MODEL.
so does instruction number 4 require a higher level of competence than that normally presumed of a shop bay dealer garage mechanic then  ;)
It says:  4. Loosen wheel axle nut
RMT1983
« Reply #54 on: 24 November 2014, 12:59:51 am »
No where does it say that you need to loosen the arm bolts when adj the chain slack, I have the origional owners manual and here is the online service guide that I downloaded from this forum
RMT1983
« Reply #55 on: 24 November 2014, 01:08:21 am »
Why cant I delete my reply, I feel stupid now!!! haha
