Date: 10-05-26  Time: 09:37 am
Author Topic: Headlight bulb change  (Read 2664 times)
Craigmartin666
« on: 12 September 2014, 12:40:00 pm »
Ithe low beam bulb went the other day, I've bought a set of Philips xtreme vision bulbs. Question is I know it's simple but how do I change the bulbs over?
greenman
Re: Headlight bulb change
« Reply #1 on: 12 September 2014, 01:24:55 pm »
Pull plug off the bulb terminals , remove rubber cover, there is a spring clip hinged at 1 side, release it and the bulb is now able to be removed. Fitting is in reverse. I found that if the bulb is not seated all the way in, I fabricated a metal spacer abont 2mm thick (not plastic, it will melt, gluing your bulb in) to achieve this, this moves the filament further back in the headlight and seams to give a better spread of light on the road or shorter bulb also does this.
Frosties
« Reply #2 on: 12 September 2014, 01:34:08 pm »
Don't forget you have 2 types of bulbs fitted. The normal dip beam is type H1 whilst the main beam or "high" is a type H4 with only one of the 2 elements wired.
Many on here have wired up the extra element on the H4 in order to have both lamps lit on dipped beam.
« Reply #3 on: 12 September 2014, 01:34:44 pm »
Have a good look before removing it where the clip actually sits, because it's a funny old shape.
Craigmartin666
« Reply #4 on: 12 September 2014, 01:54:17 pm »
Cheers guys, I thought it was that way. Always safe to ask someone who knows. Don't want to make a hash of it. The bulbs are Philips extreme vision h4s. Should be better than the stock candles lol
« Reply #5 on: 12 September 2014, 02:38:44 pm »
You haven't actually said if you've done the headlight mod?
Because if you haven't then the low beam won't be used anyway.
