Date: 08-05-26  Time: 18:09 pm
Author Topic: sooty plugs  (Read 2224 times)
keratos
  • Guest
sooty plugs
« on: 07 August 2014, 06:14:50 pm »
No relation to the puppet.,
I've got soot on the plug bottom. Each cylinder.
The ground and centre electrodes are a light white milky chocolate and I was wondering whether a k&n filter might lean the mixture too much. Strange that electrodes are mikly choc (lean mixture?) Yet sooty (not a lot tho) on plug...
? What do you think?
Also, if i did replace the air filter with a k&n , would I need to sync the carbs
Cheers
Re: sooty plugs
« Reply #1 on: 07 August 2014, 07:29:21 pm »
Maybe just old plugs, if they're all the same they probably just need changing, light brown doesn't sound too bad to me.
Can't see why a K&N would lean your bike out but nobody else's?
Didn't you say you'd already balanced your carbs?
I would've thought they would still be okay.
keratos
  • Guest
Re: sooty plugs
« Reply #2 on: 07 August 2014, 08:00:46 pm »
Sorry...should have mentioned (making assumptions again..)
- new plugs installed yesterday and gap set to 0.75mm as the spec is 0.7 to 0.8
- carbs were (?) balanced
- K&N filter ; was just wondering whether it would help run a bit leaner but then again if the electrodes are already a light (milky hint of brown) does this not suggest to lean a mixture already. Not sure how to read this?
Re: sooty plugs
« Reply #3 on: 07 August 2014, 08:22:14 pm »
You balanced the carbs, so they're okay.
New plugs, and gapped, so they're okay.
New air filter, that's okay.
There is no problem?
keratos
  • Guest
Re: sooty plugs
« Reply #4 on: 08 August 2014, 07:06:06 am »
...Except sooty plugs but I guess I'm hearing that there is no problem. Excellent. Thank you for your words of comfort
papercutout
Re: sooty plugs
« Reply #5 on: 08 August 2014, 08:21:13 pm »
Better to be running a tiny bit rich, than too lean! Mine possibly runs a tiny bit lean with a K&N and a very free-flowing exhaust... I've just changed my plugs to keep an eye on it, but no problems after a 2500 mile trip through Europe.
keratos
  • Guest
Re: sooty plugs
« Reply #6 on: 08 August 2014, 08:28:44 pm »
understood. cheers.
