Date: 29-04-26  Time: 19:00 pm
Author Topic: 4 degree ignition advancer  (Read 61581 times)
nickodemon
« on: 04 August 2014, 10:40:41 pm »
Has anyone fitted a 4 degree ignition advancer fitted to a stock fazer? What are the improvements (if any). I have one fitted to my full monty fazer and it improves it in the midrange, but want to know if it's worthwhile fitting it to a stock one.
bigbluebear
Re: 4 degree ignition advancer
« Reply #1 on: 05 August 2014, 09:11:04 am »
I'd be interested in fitting one to mine after the Full Monty upgrade from my Slip On being done in September......I'd be very interested in what this actually does to the performance and if its worth it and noticeable....I've looked at Pats Page but didn't see anything.
Peasy
« Reply #2 on: 05 August 2014, 10:15:01 am »
Id like to understand the effect on stock too  :)
bigbluebear
« Reply #3 on: 05 August 2014, 10:30:39 am »
Looking at Ivans site....you can get 147bhp with an advancer, ported boots and K&N.....
http://www.ivansperformanceproducts.com/fz1dyno2.htm
brooker81
« Reply #4 on: 05 August 2014, 11:59:09 am »
i fitted advancer to my gen 1 thou but was done at same time as Ivanisied full monty so couldnt tell the difference as i didnt know whta made the difference. :rollin They ae only like 15 quid so worth a go either way surely.
b1k3rdude
« Reply #5 on: 05 August 2014, 01:18:15 pm »
And what effect would an IA have on a normal ivanised bike (just the carbs have been done).
Falcon 269
« Reply #6 on: 05 August 2014, 01:40:54 pm »
You need to look at those a bit more closely, bbb. ;)
First graph shows a top end power loss with a 4 deg advancer.  Ivan doesn't recommend them for this motor.
The graphs showing 147bhp were for a motor with Muzzy full header system, not the Full Monty.  The best Full Monty results I've seen were 140bhp.  Your results may vary. :)
You feel the difference with an ignition advancer as sharper throttle response from idle to around 4k rpm.  It picks up a bit quicker, that's all.  No actual demonstrable gains on a dyno.
Since most of us don't routinely sit with the revs above 9k rpm, so any loss/extra vibes that high up the rev range aren't a factor.
DIY advancer option here:  http://www.yamahafz1oa.com/eskortsadvancermod.shtml
PieEater
« Reply #7 on: 05 August 2014, 01:43:16 pm »
I have one fitted to my full montied Gen1 the altered timing gives better low down response at the expense of a few BHP off the top. It's made cold starts a doddle and low rev cruising even easier,  you'd most likely notice the benefits of fitting one rather than the slight loss of top end. I don't really see what Ivanising has to do with it as the effect will be the same regardless but others will no doubt have an opinion.
bigbluebear
« Reply #8 on: 05 August 2014, 02:06:01 pm »
Not quite sure if your saying its not worth it though....any advance in acceleration sounds good to me....is it something you would recommend and could add to the full monty install
Falcon 269
« Reply #9 on: 05 August 2014, 04:01:59 pm »
I've modified the OE advancer on my own bike to give 2 degs advance because I think it's worth it.
A similar benefit can be obtained by setting the TPS dynamically as Ivan recommends - see the addendum in this post:
http://www.cartestsoftware.com/fz1/throttlepositionsensoradjustment.html
Hedgetrimmer
« Reply #10 on: 05 August 2014, 06:14:00 pm »
Hey Mike,
I know you've mentioned it to me before, but I was wondering if an advancer might be of use to me, having read your note above about it smoothing the throttle response between idle and 4k rpm.
As you know, when I first got mine, it had a very snatchy response in just that rev range at very small throttle opening increments, but the Ivanising largely seemed to cure that. Gotta say though, it is still there - not nearly so bad as it was, and I can quite happily live with it, but wondered if the advancer might improve things still further?
What do you think? Worth a shot?
slimwilly
« Reply #11 on: 05 August 2014, 06:36:52 pm »
Hey Mike,
you need a turbo to keep up with me :lol
Hedgetrimmer
« Reply #12 on: 05 August 2014, 07:18:32 pm »
Seem to remember some comment about "lighting the blue touchpaper" on Sunday?  ;)   Wasn't much in my mirrors then  :lol
slimwilly
« Reply #13 on: 05 August 2014, 07:53:49 pm »
Slow down fool :lol , mind you those bends later were fast 89 urrhh ;)
Falcon 269
« Reply #14 on: 05 August 2014, 09:06:13 pm »
Try the DIY option - definitely worth it in my view, Nick. :)
Mike
Hedgetrimmer
« Reply #15 on: 05 August 2014, 09:28:25 pm »
Mike
Ok, I'll take another look at that, cheers  :thumbup
nickodemon
« Reply #16 on: 05 August 2014, 10:29:49 pm »
Fitting a 4 degree ignition advancer to a full monty fazer gives improved low down response and possibly a couple more horse power in the midrange. it also makes starting the bike easier. It doesn't give more top end power (possibly loses a couple at the very top of the rev range (i didn't notice). It makes the bike more driveable in my opinion and better in the range of revs that i use 99% of the time. I think i will buy a £14 one off ebay for my standard fazer and see if there is any noticeable difference.
kitcrazy
« Reply #17 on: 06 August 2014, 02:45:13 pm »
ive notice my gen1 is abit snatchy through traffic.is the ignition advancer something anyone can have ago at fitting?
bigbluebear
« Reply #18 on: 06 August 2014, 03:49:52 pm »
An Ivans Jet Kit will sort that out
ogri48
« Reply #19 on: 06 August 2014, 04:14:46 pm »
I only ever tried an advancer once, on a 1200 bandit..it kinda killed it..
Falcon 269
« Reply #20 on: 06 August 2014, 04:45:59 pm »
Chain slack correct?
If you try to ride at walking speed without feathering the clutch, it'll likely snatch regardless.
An advancer won't cure this on its own although I won't hurt, either.  As for 'can anyone have a go at fitting?', sure you can.  However, you do need a bit of mechanical savvy and the correct tools to do it right. :)
'Ivanising' has a positive effect on fuelling throughout the rev range and improves driveability from idle upwards.
nickodemon
« Reply #21 on: 13 August 2014, 05:37:37 pm »
I fitted the 4 degree advancer to my standard fazer last night (15 mins), and took it to work this morning.It started quicker this morning and i didn't need to open the throttle slightly to get it to fire up.  The differences are the throttle feels more responsive, a definite improvement with vibes on the motorway and it requires less throttle when driving on city streets. I noticed in stock form the bike sometimes bogged down slightly at low revs if you gave it a handful, but with the advancer it pulls cleanly.  It's definitely worth doing either the way Mike has done or to buy one on ebay for £14.
http://www.ebay.co.uk/itm/YAMAHA-R1-FAZER-1000-CARB-MODELS-4-DEGREE-IGNITION-ADVANCER-ROTOR-YELLOW-ZINC-/151372332174?pt=UK_Motorcycle_Parts&hash=item233e7e7c8e
karlo
« Reply #22 on: 13 August 2014, 06:02:58 pm »
I can't say I noticed any power increase when I fitted mine, It just seemed to smooth the engine out a little.
Hedgetrimmer
« Reply #23 on: 13 August 2014, 06:35:58 pm »
That's what I'd be looking for. Thing's got plenty enough power for me as it is! Any more and I might as well set fire to my license and get a bus pass  :lol
nickodemon
« Reply #24 on: 13 August 2014, 08:34:51 pm »
Where did i say there was a power increase?
