Date:
02-05-26
Time:
03:04 am
Home
Media
old - Fazer Owners Club - old
dust seal
« previous
next »
Print
Pages: [
Author
Topic: dust seal (Read 1441 times)
midden
Naughty Corner
GP Hero
dust seal
on:
31 July 2014, 10:31:13 pm »
Having fitted a new dust seal in rear caliper I couldn't get the piston back in.
It's as if the seal is too thick as the piston just wanted to push the seal out of it's seating.
I've ended up putting the original back in
Has anyone else ever had this problem.
Logged
Dead Eye
Naughty Corner
GP Hero
Re: dust seal
Reply #1 on:
01 August 2014, 12:25:32 am »
Haven't had the same issue, mine seemed to do in ok - have you tried putting the piston in the freezer and using some brake fluid as a lubricant?
Logged
midden
Naughty Corner
GP Hero
Re: dust seal
Reply #2 on:
01 August 2014, 12:32:33 am »
used fluid but not the freezer bit.....
Got them from yambits so not originals. Lesson learned I think
Logged
GP Hero
Re: dust seal
Reply #3 on:
01 August 2014, 05:53:47 am »
I thought red rubber grease was the preferred lube for seals, and a safer option as well, you don't really want to be fumbling about with brake fluid getting everywhere.
Logged
Deefer666
Naughty Corner
GP Hero
Re: dust seal
Reply #4 on:
01 August 2014, 06:37:32 am »
Make sure that the groove that the seal sits in is completely free of dirt and corrosion (I use a dentist probe to clean it out) and then red rubber grease on the seal and get it sat flush. then put the piston back in but it must got back in totally straight otherwise it'll pull the seal back out.
Logged
Print
Pages: [
« previous
next »
dust seal
SMF 2.0.19
SMF © 2011
Simple Machines
Simple Audio Video Embedder
Crushing Theme by
Diego Andrés
XHTML
RSS
WAP2
