Date:
07-05-26
Time:
04:24 am
Home
Media
old - Fazer Owners Club - old
FZ6 / Fazer
Rear wheel stiff to turn by hand
« previous
next »
Print
Pages: [
Author
Topic: Rear wheel stiff to turn by hand (Read 4662 times)
clanadam
Club Racer
on:
28 July 2014, 09:03:53 pm »
Not sure if I have a problem with my 2004 FZ-6 or not. When on the centre stand the rear wheel felt very stiff to turn by hand. I took the wheel off and cleaned up (took out and scrubbed) the chain adjusters etc which were all crudded up after a couple of winter's use
I regreased the axle and put it all back together and was hopeful it was sorted as all felt good before I tightened the axle nut up. It is now better than it was but is still stiffer than I think it should be. The rear pads definitely aren't binding so any ideas what could be causing this to stiffen up? The chain is also not too tight - tested with bike off centre stand as well and it's still got some play in it.
It feels fine to ride but I'm not happy it isn't spinning as freely as I think it should - any ideas?
Thanks in advance.
Logged
Grahamm
Global Moderator
GP Hero
Re: Rear wheel stiff to turn by hand
Reply #1 on:
11 August 2014, 12:32:43 am »
If you try to spin the wheel, does it keep going or immediately stop when you stop pushing?
Also, if you've taken the wheel out, try putting in back in place without the chain around the sprocket and see how easily it spins then.
Logged
mickvp
Global Moderator
GP Hero
Reply #2 on:
11 August 2014, 12:44:22 am »
Is the axle nut done up to the correct torque?
Logged
clanadam
Club Racer
Reply #3 on:
12 August 2014, 12:47:47 pm »
Yup - torque wrench was used to tighten it up. Doesn't seem so bad now after a couple of weeks so looks like no problem. Ride more worry less
Logged
bigralphie
GP Hero
Reply #4 on:
12 August 2014, 04:10:08 pm »
Have you had 2 shredded wheat's not just one
Logged
Print
Pages: [
« previous
next »
FZ6 / Fazer
SMF 2.0.19
SMF © 2011
Simple Machines
Simple Audio Video Embedder
Crushing Theme by
Diego Andrés
XHTML
RSS
WAP2
