Date: 18-07-26  Time: 00:30 am
Author Topic: Advice on front &Rear caliphers  (Read 15022 times)
lew600fazer
« on: 21 July 2014, 02:45:46 pm »
I posted last week that I had a problem with my right side ffront Caliper photo attached. I thought I would check out the left side and the rear as well. All fecking slack been riding a death trap. Not happy I had new front pads fitted in April that garage is going to get a rocket.
I am better at maintaining rather large marine engines than FZ1's I have attached several pic's of the rear caliper as well.
I assume there is only 1 securing bolt for the rear caliper?? In the pics I am pointing at 2 bolts , top one by the bleed nipple is the securing bolt for the caliper? yes? and the other one seems to have a rubber type boot/ Is that a balancing valve for the rear ABS??? and really no need to touch this?
The top one by the bleed nipple was backed off about 4 turns, am I correct to assume that this should should tight/ I have tightened it up hard. Again I have checked the caliper assume there should be a certain amount of float/movement if you grip it and twist back and forth.
Any advice apprecated. I am going to get the bike to a dealers and get the thing checked over, not a lot of confidence in the thing now. Not good to find out the brakes are falling off the fecking thing when two days ago I had her batting along flatout.
What is really pissing me off is I had this bike serviced and MOT'd by Marriotts of Birkenhead the day before I rode her all the way down to Spain. I will be dropping them an email, makes you laugh though this bike just passed the Spanish version of the MOT last week after I had fitted a new EU headlight. All MOT's would appear to be a waste of time.
<a href="http://s1087.photobucket.com/user/lew600fazer/media/DSC_0082.jpg.html" target="_blank"><img src="http://i1087.photobucket.com/albums/j478/lew600fazer/DSC_0082.jpg" border="0" alt="Right front calliper bolt missing photo DSC_0082.jpg"/></a> <a href="http://s1087.photobucket.com/user/lew600fazer/media/DSC_0083.jpg.html" target="_blank"><img src="http://i1087.photobucket.com/albums/j478/lew600fazer/DSC_0083.jpg" border="0" alt="rear calliper photo DSC_0083.jpg"/></a>
<a href="http://s1087.photobucket.com/user/lew600fazer/media/DSC_0084.jpg.html" target="_blank"><img src="http://i1087.photobucket.com/albums/j478/lew600fazer/DSC_0084.jpg" border="0" alt=" photo DSC_0084.jpg"/></a>
<a href="http://s1087.photobucket.com/user/lew600fazer/media/DSC_0086.jpg.html" target="_blank"><img src="http://i1087.photobucket.com/albums/j478/lew600fazer/DSC_0086.jpg" border="0" alt=" photo DSC_0086.jpg"/></a>
PaulSmith
Re: Advice on front &Rear caliphers
« Reply #1 on: 21 July 2014, 05:20:13 pm »
I am not quite sure what your complaint is. An MOT is not going to check that bolts are correctly torqued, only that the brakes do their job. You can try to give out to the dealers or MOT shops  if you like, but they are going to tell you the same thing that I am. It is your bike and your life. Take as much or as little care of each as you want.
Looking at the parts fiche (which I suggest you use since you don't appear to have the Haynes manual) the rear caliper is held on to the carrier with TWO bolts, not one. Check that you haven't lost another one.  http://www.yamahamotorcyclespares.co.uk/genuineparts/13191/33/yamaha%20fz1-n%20fazer%20-%2013191/rear%20brake%20caliper?uID=0
DekF
« Reply #2 on: 21 July 2014, 10:33:19 pm »
Yeah, I agree with Paul above. It's your bike, your life, your responsibility. There's no point passing the blame onto others or bleating about what's happened,  accept it as a warning & in future take a more pro active role in the bike's maintenance. You don't need an engineering degree to check the tightness of nuts, bolts & fasteners.
The front caliper holding bolts should be torqued to 29ft/lbs & coated with blue loctite. The rear caliper bolts to 20ft/lb &16ft/lb & again coated with blue loctite.
Tightening them to "hard" isn't recognised as an acceptable measurement.
lew600fazer
« Reply #3 on: 22 July 2014, 01:56:39 pm »
To reply to above posts I agree it is my responsibility to ensure the bike is maintained in a road worthy condition. But one would expect when it is serviced by an authourised Yamaha dealer it would have had the bolts set to the correct torque and not be backing off like this. Yes I will keep a better eye on things now that I am aware that they can become an issue. I have on order a complete set of caliper bolts and will add a touch of loctite blue when fitting. I may go one step further and drill the heads and pair wire them in as extra security.
Having been at sea for 43+years as a marine engineer and the last load of years sailing an office desk so to speak one has rather forgotten engineering basics. Now I have retired I am sure I will soon catch up.
VNA - BMW Wank
« Reply #4 on: 22 July 2014, 07:25:55 pm »
Quote
You are absolutely right Lew.  If you have paid a Yamaha dealer, and no doubt paid em a fortune to service and MOT your bike you should not have screws winding out and falling off your bike and certainly not brake screws.
However you will now be aware of how shoddy dealer work can be, and yes you are better off looking after basic maintenance yourself, you'll do it right.
By the way I wouldn't use loctite, I do the opposite I stick a tiny smear of copper ease as things get hot down there and I wanna know I'll be able to pop my calliper off again.  I do like to use torque wrenches, but then again copper ease can render torque settings pointless so I do the brake calliper mounts by hand.  As a former marine engineer (mechanic?) I'm sure basic bike maintenance will come back easy to you.  Get a maintenance manual, plus there's loads of tutorials all over the web.
Give the dealer hell, get em to put things right, but the in the future - just don't bother with them, do it yourself.
ps don't forget the red rubber grease (another thing dealers don't do)
locksmith
« Reply #5 on: 23 July 2014, 09:52:15 am »
It's amazing the difference it can make, stripping the calliper off the bike, using brake cleaner, carefully moving the pistons back and forth and lubing with the red rubber grease.
Oh and then making sure the bolts are tight :lol
PaulSmith
« Reply #6 on: 23 July 2014, 04:02:44 pm »
Quote
.... I may go one step further and drill the heads and pair wire them in as extra security....
...By the way I wouldn't use loctite, I do the opposite I stick a tiny smear of copper ease as things get hot down there and I wanna know I'll be able to pop my calliper off again...
I really, really would not recommend greasing up brake bolts. Apart from the obvious reason that you have already mentioned of screwing up the torque, or the fact that you are now throwing three different metals into contact in a hot and cold environment, begging the corrosion issues that entails, it doesn't make any sense because the important thing here is not that you can lossen them easily at a later time, it is that they do not lossen for any reason without deliberate effort! Nor would I suggest that weakening the bolts that hold your brakes on by drilling holes in them couild be considered a good idea either.
When you use clean, grease free bolts in clean, grease free mountings with a decent dab of loctite and tighten to the correct torque, then the loctite will do its job and prevent vibration and heat cycles from lossening the bolt, while also provideing an anerobic seal which prevents the ingress of air, water, salt and other oxidisers, so reduceing corrosion. And the fact that you have used the correct torque means the bolt will not be stretched or damaged which in turn means it will come lose when the appropriate lossening torque is applied.
The reason most people do it this way is because it is simple and it works.
VNA - BMW Wank
« Reply #7 on: 23 July 2014, 06:40:51 pm »
Quote
Not so sure of that.
Also with extreme heat cycles, water, dirt, salt etc, well that's the reason for the copper ease.  Brake screws have a habit of seizing up.  And as they are usually screws not bolts, you don't want damage those threads (usually a steel screw into soft aluminium)
Dave48
« Reply #8 on: 24 July 2014, 08:10:26 am »
Quote
The only time I have experienced difficulty undoing brake bleed screws is where they have been over-tightened or serious corrosion(lack of preventative maintenance/regular proper cleaning) is present.
If,as PaulSmith says, you assemble clean calliper bolts into clean callipers using loctite & correct torque values,it is unnecessary to drill & lockwire said bolts.
I think the moral of this tale is that, yes in an ideal world, all bike mechanics/dealers workshops would check every fastener on bikes as part of service schedule.
However we know that this doesnt happen and the onus is on us as riders/owners to ensure our bikes are "fit for purpose".
If you look at garage bills closely the bulk of the cost is labour then add on parts at full retail value-look what they charge for say 3 litres of oil!- then to cap it all; VAT @ 20%!
Most of us on here are "enthusiastic" owners-many doing some or all of their own work on bikes/cages whatever.
Done properly it adds to the riding pleasure, knowing your bike is as good as it can be,leaving you free to concentrate on what the road brings.
locksmith
« Reply #9 on: 24 July 2014, 09:15:52 am »
Always amazes me how many right ways there are to a job on an internet forum :lol
PaulSmith
« Reply #10 on: 24 July 2014, 12:46:18 pm »
Quote
Either you didn't read, or you didn't understand what I posted. If you actually know the difference between a bolt and a screw, then you should also know that being able to loosen the caliper easily is only a secondary objective. The primary purpose of the excercise is ensuring that it does not loosen unintentionally. When assembled as per recommended best practice, you will not have a  problem with them loosening unintentionally and you will not have a problem with siezing. Done your way, you increase the risks of seizing by encouraging corrosion by introducing copper, and you increase the risks of unintended loosening by introducing grease, so failing both objectives.
lew600fazer
« Reply #11 on: 24 July 2014, 03:51:44 pm »
There is absolutely nothing wrong with drilling the head of a bolt and wiring the pair togather it is a well established and accepted engineering practice, It all depends on the size of the hole, so for instance a 1mm/1.5mm hole nothing wrong at all.
A torque wrench is only as good as the last time it was calibrated and that should be done annually, if one wants to split hairs.
The proper way and most effective method of tightening a bolt would be to apply a smear of Mollycoat G to the thread and the contact point were the bolt head contacts whatever is being torqued up that way you will achieve the correct setting.
Next time you are in a racing paddock have a look and see how many bikes do not have bolts drilled and wired, if it is good enough for the Dunlop boys will be good enough for me.
Okay explain the differance between a set bolt and a bolt
VNA - BMW Wank
« Reply #12 on: 24 July 2014, 06:36:56 pm »
Quote
Aye well, or it's amazing how complicated the simplest of tasks can become.
Lest deal with three things,
1. The Dealer
2.  The fastener and loctite
3.  Why you should use copper ease.
Oh yes Lew maybe
4 - torque wrenches.
Oh god!
1.  The Dealer
Which kinda partly covers two.  If the screw is tightened to the correct torque in this application then it will not come loose.  An annual service should include a brake inspection and clean.  The dealer will tell you to leave the servicing to them, that covers the brakes.  The dealer either did not torque the mounting screws or did not apply enough torque (see 4).  If you had your car serviced you might be a bit peeved if the brake callipers fell off - it's no different for a bike.  Lew should complain to his dealer and his dealer should, if they accept his complaint, make him happy (I mean really make him happy - they focced up big style).  Loose calliper mounts are unacceptable.
Quote
That is achieved by applying the correct torque to the mounting screw.  Perhaps if somebody has the official Yamaha they can tell us if Loctite (or similar) is recommended.  There is no mention of it in my clymer  manual.  Logically I don't think it would be.
Quote
Indeed you need to prevent the ingress of water (we'll come to the reason for that in a moment) but to do so you need to cover the whole thread in loctite.  Now we have a screw that goes into a soft aluminium thread and a darn good bond along it's entire length.  There is now a danger (I think) that the loosening torque will considerably exceed the tightening torque and result in possible damage to the thread.  Not a problem with a nut and bolt arrangement, if they seize for whatever reason get em off and throw away.  Damage the thread on your calliper mount and you might want to cry.  Do correct me if I am wrong, perhaps with your source, but I don't think is best practise.
3.  Why you should use Copper Ease
Quote
Cheeky foccer :lol
What I have done is introduced an anti-seize compound to protect the soft aluminium threads.  You are correct that the reason we have an issue here is due to two dissimilar metals.  You may well find that many maintenance manuals do not mention the use of an anti-seize compound.  The reason for this is, I suspect (and I'm taking a guess here), is that they are written in dry climates.
For the metals to react we need to introduce water to start the electrochemical process.  You then get erosion of the most chemically active metal, in our case it will be the aluminium, plus you begin to form a bond.  We need to protect that precious aluminium at all costs, we can't just throw it away like we could, if we wanted to, the screw.
So as we live in a wet climate (certainly I do in Ayrshire, umm though right now I think I'm stuck in the Bahamas!) we need a solution.
So we introduce our magical anti-seize compound.  It's copper carried in a grease.  The grease will exclude the water so hopefully we won't get any electrochemical reaction.  But just in case, and with all that heat and yup water, our grease will very probably get burnt off or washed away, so we have the copper. The copper is nice and soft so we'll be able to get the screw back out but also it's gonna act as a sacrificial metal.
When the water gets in, as the copper is now the most active metal in our mix, it's the copper that will be eroded and in doing so protects our soft aluminium thread.  Copper ease is perfect and recommended in our climate for use on brake calliper mounting screws.
4.  Torque wrenches and settings.
If you are worried about the torque setting when using copper ease, with a bit of googling you should be able to find correction tables for various anti-seize compounds.  You need to also check the manufactures figure to make sure grease or anti-seize compound has not already been recommended and already factored in.
In my personal opinion, if you are going to use  torque wrenches (not everybody will agree with this) then get good uns.  I like Britool, but Norbar, Facom, Bacho and the like are all good.
If you really wanna get it spot on buy a quality torque wrench analyser and get it calibrated every other year (needs to be mounted on a solid bench by the way).  Most of the torque wrenches we have at work have ranges marked on them but no scale.  They are set up, checked for repeatability, locked and a certificate issued.  They are then used and rechecked and part two of the certificate completed.
Me?  I've been copper easing they brake mounting screws and nipping em up by hand (more accurate than a cheap torque wrench?) for over 20 years and I've never ever had one come loose and nor have I ever had a problem getting em back off.
So I suggest Paul that you pop your callipers off, clean all the loctite off the mounting screws and apply a thin smear of copper ease on the threads and reassemble.
Phew.
PieEater
« Reply #13 on: 24 July 2014, 07:34:42 pm »
Nothing useful to add, but glad after 48 years I finally know difference between a screw (a threaded fastener you measure torque from when tightening its head) and a bolt (a threaded fastener that you measure torque from when tightening a nut),  so thanks.
lew600fazer
« Reply #14 on: 25 July 2014, 01:58:39 pm »
A Set Bolt has a full thread the length of it a Bolt has not.
lew600fazer
« Reply #15 on: 25 July 2014, 02:01:53 pm »
Just toss this one into the mix, are there helicoils fitted to the Callipher securing bolt threads or are they tapped Alloy?
Would be quality if they had Helicoils fitted as standard.
PaulSmith
« Reply #16 on: 25 July 2014, 02:58:24 pm »
There is absolutely nothing wrong with drilling the head of a bolt ...
Of course not, if you do it right. However, you have not really shown any evidence that you are the sort of person likely to do it right. The mere fact that you are suggesting it as a possible solution to you not checking your own bike after someone else works on it re-inforces that opinion. I will be happy to apologise if I have mis-judged you, but I do suggest you take another stroll down pit lane to see which bolts are wired and which are not. In my experience, the bolts that would put others at risk if they failed (oil, coolent etc) are the ones that are wired. The ones that would just kill you are your own problem. I have certainly never seen brake bolts being wired as it would take far to long to change the pads.
I could not agree more...
I actually agree with most of what you have written but the bit that worries me is...
Quote
but in your own words, "but then again copper ease can render torque settings pointless".
Your only real objection to using loctite seems to be that
Quote
"There is now a danger (I think) that the loosening torque will considerably exceed the tightening torque and result in possible damage to the thread".
If you read up on loctite you will see it is true that the loosening torque exceeds tighening torque, but not to the point where is a serious concern.  Certainly, in my opinion, it is far less of a concern then using guesstimated torque on greased up bolts holding safety equipement in place. There are exceptions of course, but they tend to concern tightening torques that deliberatly strain the bolts and so do not apply in normal motorbike DIY maintenance.
Finally, you asked if Yamaha recommeded the use of loctite on these bolts, which seemed like a reasonable question. And even though I knew that they would, I checked anyway so I could quote it to you and according to the service manual I have (2001 5LV1-AE1 section 4-16) , I am quite embarressed to have to admit that they do not. 40Nm but no mention of loctite.  I would have put money on it, but there we go. And no, they do not suggest copper grease!
VNA - BMW Wank
« Reply #17 on: 25 July 2014, 07:12:29 pm »
Quote
The last time I had a dealer service was 2005.  I took my thou in to get it serviced purely to keep my warranty valid.  The price then was 55 quid and hour plus VAT!  I hate to think what it is today.  Franchised dealers will tell you that they are the servicing experts, that and considering the rates that they charge means you should not have to check their work.  Nor do all riders own torque wrenches, know what the torque setting is, so forth and so on, which is why a lot of people pays others - the experts - to do the work.
The bottom line here is that the dealer failed to tighten the mounting screws correctly.  Or, hey who knows maybe Lew rides everywhere like he's in the TT, but I kinda doubt it.
I think what we might both agree on - is that the 'experts' ain't as smart as they'll tell you they are, and that too many dealers are just smart looking polished cowboy outfits (not saying there ain't some spot on dealers and workshops out there)  So yeah, it's a good idea to take an interest in your bike, learn simple basic maintenance like brake calliper cleaning, save some cash and know the job is done right.
Perhaps the race series that you participated in Paul did not require any brake lock wiring but many others do.  Some wiring is mandatory, some recommendation.  Google is your geek - so here's a prep guide to The Manx Grand Prix.
http://www.manxgrandprix.org/MGP-Info/Machine-Preparation
Quote
Read 4 again in my previous post.  Think carefully about your use and reliance on torque wrenches.  Again google is your geek - there are correction factors for using anti-seize compounds.  Note I say anti-seize compound not grease.
Quote
You might wonder why racers have to lock-wire the calliper mounting screws when loctite arguably could do the same job.  Lets first accept that race bikes are used differently and subject to serious amounts of abuse when compared to any road bike.  We need belt and braces here.  So, there are probably two reasons why lock-wire is the preferred belt and braces method and not loctite.
1.  The application of loctite cannot be satisfactorily inspected by the race tech inspector.
2.  Using loctite on frequently dismantled parts (ie for regular maintenance) is not generally recommended, and less again so on aluminium threads.
I would take a guess that if racers were given the option of using loctite on callipers mounts (oh so quick and easy) and/or lock-wiring if required, they would all pick lock-wire and no loctite every time.
Quote
It's not a grease, it's an anti-seize compound.  Steel onto steel the soft copper will allow you to loosen that thread.  Steel onto aluminium it will not only allow you to loosen the thread but also protect that soft aluminium thread by acting as a sacrificial metal.
Lew,
Don't go daft and lock-wire your calliper mounting screws, and for God's sake don't touch that loctite (you probably know that anyway) just stick a wee smear o copper ease on the threads and nip em up - job done.
richfzs
Re: Advice on front &amp;Rear caliphers
« Reply #18 on: 25 July 2014, 09:03:39 pm »
Neither have you really, have you? Preaching about loctite-ing the bolts...
In a sense, fair play in that you've come back and admitted you were wrong, but if VNA hadn't argued with you, that wouldn't have happened, would it?
Be careful out there kids, don't believe what you read on the Internet, there's a lot of people out there don't know what they're talking about...
VNA - BMW Wank
« Reply #19 on: 25 July 2014, 09:49:36 pm »
Quote
Not like me to argue with someone, eh? :lol
But seriously, Lew's had a problem, asked a question and he's been slagged off and fed a load of mince.
And Paul is still determined to use that loctite.
Quote
Aye, and everyday is a learning day.  We all foc stuff up now and again.  I have to say this is the first I'd heard of calliper mounting screws being loctited.
Google is your geek, and Paul's statement that it's best practise and what most folks do had me googling.  And indeed lots of folks are doing it, many claiming that's what the manufactuerer recommends and perhaps they do.  But googling also reveals a lot of folks asking how to fix their stripped calliper mount threads  :eek   And guess what they were using.
Another thing that's all over the internet is not to use copper ease as apparently it'll cause terrible corrosion when in fact with a steel screw and an aluminium thread it's a life saver, or rather a thread saver.
But hey that's the internet for you.
lew600fazer
« Reply #20 on: 25 July 2014, 11:15:31 pm »
This one is aimed at Paul, why are you getting personal??All I did was ask a question and now I am getting slagged off. You said I do not seem to be the sort of person capable of drilling holes in bolt heads.
Well lets see now I am getting on a bit in years pushing 66 now. I have an engineering background for the last 50 years.
I served my apprenticeship as a tool maker, 5 years that lasted. I actually made machine parts etc!
I then entered the Merchant Navy in 1969 as a Junior Engineer and progressed through the ranks. I was a slow starter as in bothering to get professional qualifications. I was happy plodding along as a 3rd engineer.
Having worked with several people on a higher pay scale and younger than me and who where serving as 2nd Engineers and in a few cases Chief engineers a lot of whom were very good at what they did. There were a few idiots. So I decided to improve my professional qualifications gaining my Class 2 engineering certificate and going on to gain my Chief Engineers certificate in 1999.
Now a certain Shipping company 12 years ago decided that they would trust me by making me Chief Engineer on Crude oil Carriers, Product Carriers, Chemical Carriers, Roro ferrys ,LPG gas carriers, LNG Gas carriers. I spent 2 years overseeing the construction of 3 LNG Carriers in ship yards in China.
Now I will admit that over the years I may have lost perhaps a wee bit of hands on experience, BUT I think I could manage to drill a couple of holes in a bolt, also I would understand why I would want to do it.
Also will still run with the racing guys will pair wire there brake bolts, why NOT especially seeing as you do not need to remove the calipers to change the brake pads.
Or have I been miss informed and Marriotts motorcycles of Birkenhead are talking a load of shite.
See there reply below as I asked them if they checked the bolts when they changed my pads. Now I will admit I am not any great shakes at being a motorcycle mechanic as I have never really had the time or the interest. I will be taking more of an interest now. I am not impressed that they did not service the pistons etc! while replacing the pads. In their defence though I was pushing them to crack on as I was travelling down to Dover from  Birkenhead (325 miles) and onward down through France and finally Spain 1800 odd miles
 I have spoken to martin regarding the calliper bolts and he’s confirmed that the callipers where not removed whilst changing the pads, the pads pull out from the rear of the calliper once the pin is removed.
Now Paul just wondering what your enineering background is, qualifications and years of experience?
Do I think I could or am capable of drilling a hole in the head of a bolt, yea I reckon I could. I reckon I could even make the fecking bolts.Oh I am not getting personal here just curious.
lew600fazer
« Reply #21 on: 25 July 2014, 11:37:06 pm »
Ah you do not need to remove the bolts to change the pads, just knock the pins out and the pads slip out the back, or so Marriotts of Birkenhead informed me today
Quote
Quote
richfzs
« Reply #22 on: 26 July 2014, 12:30:06 am »
There's a few folks on this forum, I would take their word as it stands and not check up on it. PaulSmith is definitely not one of those.
Andy, you argue? You've got the wrong fella  :rollin I do miss some of the barneys that went on, on here (Iano, anyone  :lol :lol ), some of these bairns don't have a clue how to argue  :angel  Get me, old foccer.
Back on topic, having a go at lew is utterly pointless, achieves nothing other than bad feeling. FWIW, I've got a pretty high level of contempt for dealers full stop. In the last 13 months, I've had atrocious service from my local BMW & Triumph dealers (safety critical and major engine work messed up that would have resulted in engine failure, respectively), and before that from a Yamaha dealer (again safety critical). I've got a bike in that Yamaha dealer right now (because I simply didn't have the time to do it myself) - I'm picking it up tomorrow, going to be interesting to see if there's anything screwed up this time.
Just because you're paying someone a small fortune, well that's no guarantee of quality. As others have said, know your bike, learn some basic bits and pieces, you'll save yourself a fortune (and maybe your life), and it'll be more interesting as well :thumbup
VNA - BMW Wank
« Reply #23 on: 26 July 2014, 12:01:11 pm »
Quote
Shocking really.  You pay em good money and they do a shoddy job.  If the pads need changed then the calliper and it's pistons need cleaned.   Gradually the pistons get caked in crud and stop moving, they can also corrode, crud and corrosion can lead to lead to piston seal failure.  Experts?  Shoddy shoddy workmanship.
Perhaps what the dealer is doing is the minimum, knowing that you'll eventually come back in needing a full calliper strip and rebuild.  So by doing the minimum now they can rip you off for a fortune later.
These guys are charging you top dollar for a crap job.
Or perhaps they are just bull shitting you, it's a good excuse for having forgotten to nip up the mounting screws - 'oh actually we never took em off'
Either way, I wouldn't be back there Lew.
lew600fazer
« Reply #24 on: 26 July 2014, 03:56:08 pm »
Quote
I am very disappointed with them especially seeing as I bought a new Z1000SX form them back in 2011 and they did excellent work on that bike for the time I had it.
I suspect as the service tech knew I was heading down to Sunny Spain with the FZ1 and unlikely to return as I live here now. The attitude has been sod it, very disappointed as over on the Z1000SX forum I have been singing there praises for a couple of years now.
