Date: 02-05-26  Time: 03:03 am
Author Topic: battery charged now servo does not self test but works?  (Read 2194 times)
harrness
« on: 17 July 2014, 09:36:30 am »
Could really do with some help :o
2001 Fazer 1000
Battery went flat over winter, charged battery, bike starts and run great, Exup servo and exhaust valve work fine when I rev engine.
problem is when ignition is turned on, servo does not self test, immobiliser light does not flicker, sometimes relay makes a clicking sound like when battery would be flat.
I have attached a car battery via jump leads, same result.
help please :'( :'(
schlumpf
Re: battery charged now servo does not self test but works?
« Reply #1 on: 17 July 2014, 10:01:30 am »
Be cool, no worries. The Exup does not have a self test. With ignition the Exup goes to its parking/neutral position. It does not make any move at next ignition off/on, except the engine has been started in the meantime.
Your bikes doesn't have an immobilizer light. Or did you add one?
Clicking might come from the fuel pump.
Or did I missread it and the bike doesn't start anymore?
harrness
« Reply #2 on: 17 July 2014, 10:36:12 am »
many thanks for your reply.
the bike had a red flashing light on the instrument panel before battery went flat, I thought that was a alarm light. I have not fitted an alarm but thought the light was a sign of an alarm fitted.
the bike starts and runs fine.
sorry, it was the servo that self tested on turning on the ignition
