Date: 08-05-26  Time: 21:38 pm
Author Topic: suspension setup help needed  (Read 1842 times)
keratos
  • Guest
« on: 10 July 2014, 09:26:32 pm »
read this,
http://foc-u.co.uk/wiki/index.php?title=Suspension_setup_advice
but it talks about "bottom yolk" and "top of slider" - where are these , pics???
also, talks about subtracting the larger of two from the smaller of two? what two? also, if you subtract a large number from a small number you end up with a negative number ??
noggythenog
Re: suspension setup help needed
« Reply #1 on: 10 July 2014, 09:47:23 pm »
Have you seen todays suspension thread...i think it would benefit you.
Very complicated subject but if you can only adjust preload then this could be the thread for you.
See member Joerock's advice. 8)
http://foc-u.co.uk/index.php/topic,13958.msg158029/topicseen.html#new
Edit......by this i dont see myself as a suspension pro.......i am having my own issues with my Fz1 but all i can say is that it is more adjustable which only makes it much more difficult to try and adjust and more things for me to mess up but i am getting somewhere.......use test rides and a feeling of how you think the bike is rather than what others think you should have but in basic terms you do not want to be riding a see-saw with too much lurching back and forward.....it should be small and controlled movements.
