Date: 07-05-26  Time: 02:10 am
Author Topic: C0 settings s1  (Read 5072 times)
yourebarred
C0 settings s1
« on: 08 July 2014, 04:40:22 pm »
Please point me in the direction of a thread regarding this if there is one, I did search but couldn't see one.
C0 settings? I have a 2006 model.
Mine were C1  -5, C2   9. Upped them both to 20, but felt idle to 3000rpm was way too rich so went to C1  15, C2  29 keeping the ratio the same.
Were yours at -5, 9 from factory?
What did you change to and did it help smooth things out with aftermarket exhaust?
yourebarred
Re: C0 settings s1
« Reply #1 on: 07 August 2014, 08:49:24 am »
Anyone?
Fazafou
Re: C0 settings s1
« Reply #2 on: 07 August 2014, 10:06:11 am »
Can't comment on the fazer, but I looked into this on my old TDM which would have been the same setup (2005 model), as far as I know the CO level on the display is set up at factory for that particular bike, and you shouldn't adjust just because someone else's is different I.e. your changes are only relevant to your engine.
Also the numbers can be vastly different between cylinders.
The only true way to know is put a AFR meter in the exhaust while you fiddle to see what the ratio is.
I upped them both by 10 though which stopped it stalling at the lights.
