Date: 08-05-26  Time: 10:21 am
Author Topic: carb balance  (Read 2703 times)
kelly1
carb balance
« on: 04 July 2014, 04:36:43 pm »
 hi  tried to balance carbs with a morgan carbtune  carbs 1and2 ok carb4 ok carb3 goes to the top of the tube and will not balance suggestions please
Re: carb balance
« Reply #1 on: 04 July 2014, 04:50:50 pm »
You should be balancing 1 with 2 together first.
Then balance 3 with 4 on their own separately.
Then with the middle screw adjust until 1&2 are level with 3&4.
Punkstig
Re: carb balance
« Reply #2 on: 05 July 2014, 10:44:32 am »
Have you checked there's no problems with the connection on No. 3?
Does that tube have the 2 little tubes inside to throttle the compression?
Have you swapped the tube onto another cylinder to confirm it's not the tube/ gauge at fault?
Jamieg285
Re: carb balance
« Reply #3 on: 07 July 2014, 12:50:44 pm »
Then go back and re-do 1&2 as they will have changed, then 3&4, then 1&2 again, then the left pair to right pair again.  Repeat for about an hour until it finally all lines up.  :D
keratos
  • Guest
Re: carb balance
« Reply #4 on: 07 July 2014, 09:36:54 pm »
Liked this post, I'm trying to get down to an hour but never manage  :rollin
HarryHornby
Re: carb balance
« Reply #5 on: 08 July 2014, 10:41:15 am »
Took me about an hour last time too, I now need to find a field to do mine in though, because my new exhaust and living in a very respectable close doesn't make for keeping the neighbours happy when doing my carbs LOL
