Date: 01-05-26  Time: 10:57 am
Author Topic: Fitting new MIVV exhaust! RESULTS!  (Read 8614 times)
Krezi
« on: 02 July 2014, 09:36:16 am »
Hi Guys,
I took the plunge and got MIVV GP exhaust in carbon black which arrived yesterday. I am in two minds about either fitting it myself or getting a garage to do it. I am not a mechanic or anything but have a set of tools I use to change oil and do some little things around the bike and DIY
Looking at the instruction it seems like a straightforward job no cutting required or anything. Am I missing something? Where is the trick if any? For those who fitted an aftermarket exhaust yourself how long did the job take?
Thanks
Paul
Rexr
Re: Fitting new MIVV exhaust!
« Reply #1 on: 02 July 2014, 09:49:52 am »
It's straight forward m8 took me half hour tops, if u can change the oil and filter then changing the exhaust is easy
brooker81
« Reply #2 on: 02 July 2014, 10:04:48 am »
piss easy 10/20mins.
slappy
« Reply #3 on: 02 July 2014, 10:17:27 am »
Fitting an end can is a lot easier than doing an oil change, and you will find the more you do easy stuff like that it all helps to gain confidence for the more complex jobs.
bri h
« Reply #4 on: 02 July 2014, 10:34:08 am »
I was in the same situation as you with my gen 2 so I had a go and appart from nuts and bolts being a bit shit it was an easy job.
Krezi
« Reply #5 on: 02 July 2014, 09:47:07 pm »
Cheers guys for all good advice!
Just finished fitting and it was very simple job indeed. Just two bolts really... Very pleased with looks, just started her for a sec and it's a nice growl now...in addition to some more BHP! Didn't want to annoy neighbours at this hour  ;)
DB killer is fitted with a rivet. I presume the head needs to be drilled out to and then it will fall out?
See some pics below with new ASV levers!
Paul
Re: Fitting new MIVV exhaust! RESULTS!
« Reply #6 on: 02 July 2014, 11:00:53 pm »
Could be the photo angle but it looks like you have the clamp fitted incorrectly.  You seem to have put one end of the clamp either side of the mount.  Both ends should be together.
Krezi
« Reply #7 on: 02 July 2014, 11:47:10 pm »
it's just photo! They are together on outside end. The bracket would not fit properly otherwise
Paul
Rexr
« Reply #8 on: 02 July 2014, 11:48:44 pm »
I drilled my rivet out before putting the can on the bike.......as for the foccer said above yes it does look like u've made a mistake, with my Mivv there was a long mounting bolt with a big cotton reel type spacer, I junked this and used a shorter bolt......(both ends of the clamp should be mated together on the outside of the foot peg bracket)
Krezi
« Reply #9 on: 02 July 2014, 11:53:30 pm »
I used original bolt which is a bit too long to be frank. I still used the reel spacer on the inside as per instructions with clamps mated on the outside. It feels solid.
I presume you drilled the head inside the exhaust? I will see about the noise with baffle in and might get the baffle out
Paul
Krezi
« Reply #10 on: 03 July 2014, 08:43:33 am »
Hi Guys,
I uncovered the bike today and what the hell have I done was the question coming to mind. As some of you pointed out correctly I bolted the bracket on both sides! I adjusted quickly...
Now this sound is lovely. Not high pitched but deep growl changing into scream on higher revs. I will take the baffle out for comparison but so far I am well pleased.
Paul
« Reply #11 on: 03 July 2014, 11:46:29 am »
Good to know my old eyes aren't quite that bad just yet ... ;)
onejay
« Reply #12 on: 09 July 2014, 10:15:56 pm »
nice looking can
i need to purchase something for mine but i am unsure of what to get
Krezi
« Reply #13 on: 10 July 2014, 12:32:22 am »
nice looking can
mivv gp sounds great, noisier than stock and nice growl, took the baffle out but too noisy and kinda in your face so now baffle back in
Paul
