Date: 08-05-26  Time: 09:06 am
Author Topic: R6 speedo??  (Read 2139 times)
reddave101
R6 speedo??
« on: 01 July 2014, 03:56:59 pm »
Does anyone know if the r6 speedo 97-02 will work with a fazer 98? The connector block looks same size but the only difference is, their are 10 pins top and bottom of the fazer clocks but only 6 are used at the top and 9 at the bottom... The R6 has 8 pins at top and 8 at bottom on the clocks.. The only difference I could actually think of would be, the fazer has 2 indicator lights and oil low level light and the R6 only has 1 indicator light and no level light... Obviously I know abit of wiring may be involved but will the digital speedo work and tachometer as not sure if sensor are different??
Thanks in advance for any info
Punkstig
Re: R6 speedo??
« Reply #1 on: 01 July 2014, 05:11:59 pm »
The sensor on the fzs is completely unique unfortunately!
reddave101
Re: R6 speedo??
« Reply #2 on: 02 July 2014, 10:35:08 am »
Thanks for the reply.. Their goes another idea :'(
Punkstig
Re: R6 speedo??
« Reply #3 on: 02 July 2014, 01:20:59 pm »
Not saying it's impossible, but a thorough knowledge of electrics would be necessary.
