Date: 08-05-26  Time: 09:06 am
Author Topic: rattle on tick over until clutch pulled  (Read 5543 times)
scoobie_paws
« on: 14 June 2014, 09:49:28 pm »
Hi all been fettling the new girl and noticed that she is quite rattly on tick over until I pull clutch and  then goes quiet.
Could this be cam chain tensioner? Thought that would continue clutch in or out but not sure
Is it normal or do I need to poke about in the clutch?
On plus side new conti road attack 2 tyres on today and feel nice but will run in tomorrow :-)  also new ebc hh pads at front as old ones had about a mm left :-\  tried to replace sprocket but with 12 mm but looks like a two man job as just turns motor over with breaker bar.... Still least it means old one won't come off anytime soon
Cheers
Mark
Andy FZS
Re: rattle on tick over until clutch pulled
« Reply #1 on: 14 June 2014, 10:24:53 pm »
It sounds like the clutch rattling it can often be improved by balancing the carbs.
scoobie_paws
« Reply #2 on: 15 June 2014, 09:02:27 am »
OK great. Would never have thought of that. Will give it a try :-)
HarryHornby
« Reply #3 on: 17 June 2014, 09:34:26 am »
mine's doing that too...... time to upset the neighbours by balancing my carbs...... unless anyone else has any other ideas....
mick0905
« Reply #4 on: 17 June 2014, 09:06:33 pm »
I just joined the forum to search for the same problem. Mine sounds like a road whacker on tickover in neutral but the noise goes away when the clutch is pulled in. I've read posts on other sites saying this is "normal", is it really?  :rolleyes
« Reply #5 on: 18 June 2014, 12:26:49 am »
They all rumble like that sir.  :lol
Typical of multiplate wet clutch in line fours, balancing the carbs helps, but never completely gets rid of it.
You should listen to an old SOHC 750-4 Honda
midden
« Reply #6 on: 18 June 2014, 01:26:17 am »
you could also try adjusting the clutch cable a little to take some of the slack.  May reduce it a little, no harm in trying.
mick0905
« Reply #7 on: 18 June 2014, 08:19:06 am »
I need to hear another one. I seriously thought I'd bought a pup til I read it was "normal". What I don't know yet is how normal is normal.
The bike rides fine and selects all gears smoothly but I get the feeling when I'm stopped at traffic lights that everyone is looking round to see where the racket is coming from.
I'll see if I can upload a video of mine running to Youtube so you can compare it to yours scoobie.
His Dudeness
« Reply #8 on: 18 June 2014, 12:35:07 pm »
Maybe your clutch basket is a bit worn and the plates are rattling around a bit
mick0905
« Reply #9 on: 06 July 2014, 03:37:16 pm »
Took mine on an 80 mile ride today and the noise is seriously disturbing, spoiling what would otherwise have been an enjoyable ride but I had the constant nagging at the back of my mind that it was going to self destruct at any minute. :\
I've uploaded a video to YouTube demonstrating the noise in neutral with clutch in/out. Do they all *really* sound like this??  :eek
« Reply #10 on: 06 July 2014, 04:47:51 pm »
That is most certainly not your normal Fazer clutch rumble and they definitely do not all sound anything like that. :eek
Buy a clutch cover gasket, put the bike on the side stand (saves having to drain the oil) and take off the clutch cover and have a good look at the clutch, Sounds like something broken or badly worn.
If necessary take out the plates and check everything inside there. You could have a loose of broken clutch bolt.
If the clutch was changed there is a good chance  the clutch bolts were over tighten and one was stripped.
