Date: 29-03-26  Time: 18:16 pm
Author Topic: Removing heated grips  (Read 2020 times)
slimwilly
« on: 07 June 2014, 09:37:22 pm »
So i have some replacement handlebars, the mechanical fixings will be ok to remove but the heated grips,,well i guess the are glued on, how do i go about getting them off without fecking them up?
midden
Re: Removing heated grips
« Reply #1 on: 08 June 2014, 01:48:03 am »
wd40  and something long and flat like metal potato skewer to get between bar and grip and then twist and pull gently :)
slimwilly
« Reply #2 on: 08 June 2014, 07:44:12 am »
A job for this week nights, i will go careful.ta Neil
slimwilly
« Reply #3 on: 08 June 2014, 07:44:42 am »
Then i got to glue them back on,,what with? any ideas
midden
« Reply #4 on: 08 June 2014, 09:26:50 am »
Try a little contact adhesive.  Or some one posted before about using hairspray.
Skippernick
« Reply #5 on: 08 June 2014, 11:55:55 am »
http://fazerowners.yuku.com/topic/5650/HOWTO-Fit-your-heated-grips-PICS-BACK#.U5RA78Ysyl0
Use this guide from the old forum, tells you how to get old grips off and what to use to install the new ones, it works as i still have my original grips.
Hamos
« Reply #6 on: 08 June 2014, 09:05:09 pm »
brake cleaner,  Work a screwdriver gently in just a little, then get some brake cleaner with the straw on the nossle and give it a good squirt.  Keep trying to wiggle the grips and more brake cleaner and they will come off unharmed.
slimwilly
« Reply #7 on: 08 June 2014, 10:40:35 pm »
Well i got the left hand side off,, its fucked, i thought it was just rubber, so i went prizing the rubber bit from the bars,,only to find it was on a hard plastic sleeve,, i prized that off and they came off,,
They did only work on low heat so were on their way out,,i do have a pair of new ones here to go back on,,from the forum £50 if i remember.
MarkWales
« Reply #8 on: 07 September 2014, 03:04:20 pm »
great find skippernick saved me looking - going to wire mine this afternoon possibly
VNA - BMW Wank
« Reply #9 on: 07 September 2014, 04:52:04 pm »
Yup brake cleaner for getting em off, it eats super-glue.
