Date: 06-05-26  Time: 00:33 am
Author Topic: S2 Eurofazer peeps  (Read 6154 times)
BIG MAC
S2 Eurofazer peeps
« on: 06 June 2014, 09:40:37 pm »
Any of you guys experienced uber twitchy handling - bike twitching from the rear over white lines IN THE DRY!! More to the point has anyone found a cure for it?
Re: S2 Eurofazer peeps
« Reply #1 on: 06 June 2014, 09:56:58 pm »
Worn swing arm bearings or squared off tyre.
slimwilly
« Reply #2 on: 06 June 2014, 10:40:56 pm »
I suspect  "normal"
if the white lines have built up paint then you will feel a quick pull to the left or right,,because your weight is usually on the center of the tyre , but as you go to the raised white line suddenly your weight is on the edge of the tyre that is raised of the floor by the paint,so you fall away from it and as you cross it you will pull towards it,
it is unnerving but you should expect it.
Millietant
« Reply #3 on: 07 June 2014, 08:06:12 am »
Worn tyres normally when this has happened to me.
Lez72
« Reply #4 on: 07 June 2014, 09:27:24 am »
Another guess at worn tyres.
chaz
« Reply #5 on: 07 June 2014, 10:14:59 am »
too much gas, the bike not you, take it you are overtaking when it happens? hit a catseye and the front lifts/wobbles, I try to cross them as fast as possible in the wet or dry.
BIG MAC
« Reply #6 on: 07 June 2014, 01:00:22 pm »
I suspect tyre choice may be implicated. I have owned 3 FZS's which haven't been so twitchy. Tyres aren't squared, no float in the swingarm bearings Itys only done 6,000 miles - think I will play with suspension settings - maybe that its a weight distribution thing -ie too much around my middle lol!
johna6968
« Reply #7 on: 07 June 2014, 09:04:08 pm »
Used bikes can look identical in every respect, yet rarely do they all ride the same.. ime
